Over The Range Microwave Too Small - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Marson
Old 02-16-2018, 06:21 AM   #1
Rewards Points: 136
Over the Range Microwave too small
I was curious how often this comes up, but my new cabinets make it too small to install an over the range microwave that is 30"
The space I have after cabinet installation is 29 3/8s - In this case I have a half free floating wall side with corner bead. Should I cut into that or into the cabinet?
WalkThisWhey is offline   Reply With Quote
Old 02-16-2018, 06:25 AM   #2
Guapo
Rewards Points: 11,950
Re: Over the Range Microwave too small
I wouldn't cut the cabinet unless the overhang bothers you. The 1/2" isn't going to make a difference when it comes to support.
Guap0_ is offline   Reply With Quote
Old 02-16-2018, 08:24 AM   #3
Rewards Points: 898
I’d rip the 1/4” flanges off the left side of the cabinet to the right of it and remove the corner bead. Or you could remove both 1/4” flanges from the cabinet next to the mic..
An OTR mic. is just under 29-7/8” wide
BIG Johnson is offline   Reply With Quote
Old 02-16-2018, 08:31 AM   #4
Rewards Points: 944
Cut into the drywall. I assume the faceframe of the cabinet above is 30". If you cut into the cabinet, it's really going to look like a hack job, because then the micro won't line up with the cabinet above. And what about the range? Are you just holding that off of the wall so it misses that corner?
WalkThisWhey likes this.
Marson is offline   Reply With Quote
Old 02-16-2018, 05:54 PM   #5
Rewards Points: 136
I thought about it and yes I am going to cut into the drywall - a cabinet cut would look awful.
Range is off the wall now but will be pushed back to the wall after the install is done
Can't remove Whirlpool Over the range Microwave kzukowski Appliances 22 04-07-2017 02:09 PM
Over Range Microwave Venting SS396 Appliances 1 01-03-2016 12:03 PM
Range Hood on Microwave Circuit - Legal? Thadius856 Electrical 18 08-10-2012 11:25 PM
plugging OTR microwave into the range jpenns Electrical 13 01-30-2011 07:28 AM
HELP. I really need some advice on how to remove an over the range microwave! justmeee Appliances 9 12-24-2009 03:47 AM
