Outlets & Under Cabinet Lighting / Wiring Advice/recommendation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-21-2016, 02:20 PM   #1
Rewards Points: 238
Question
Outlets & Under cabinet lighting / wiring advice/recommendation
Afternoon all, remodeling entire kitchen and want to do under cabinet lighting (maybe some in cabinet also). What do you all recommend for wiring and/or type of lighting. I would want something that can be dimmed (and most likely hooked up to some type of zwave switch). I know that some LED strip lighting can get very expensive while I see deals for LED lighting for very cheap. Any recommendations for brands? I know some of the cabinet places I went to offered to install lighting, but I'm skeptical as to the quality.
Also, is there any alternative to the electrical outlets every X feet per code? The aesthetics of the outlets are not appealing.
nutshellml is offline   Reply With Quote
Old 03-21-2016, 09:14 PM   #2
Rewards Points: 996
Re: Outlets & Under cabinet lighting / wiring advice/recommendation
i gutted my kitchen to studs. i ran 120v outlets to each cabinet bank, 3. 1 outlet inside a cabinet. all connected to 1 switch. i used $40 each led multi colored & dim-able for each bank. transformer is just in the back of the cabinet plugged in. drill small hole on the back for the low voltage light wire AND the sensor ! then just put the led's where you want them and run the wire.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
nutshellml (03-21-2016)
Old 03-21-2016, 09:56 PM   #3
A "Handy Husband"
rjniles's Avatar
Rewards Points: 606
Run plug mold just below the cabinets.
My electrical answers are based on 2014 NEC, you may have local amendments.
The Following User Says Thank You to rjniles For This Useful Post:
Old 03-21-2016, 10:07 PM   #4
Rewards Points: 238
Fix'n IT - do you have a picture of final product? We will be taking our kitchen down to studs also.
Old 03-21-2016, 10:10 PM   #5
Rewards Points: 996
i am going to bed now. i will post pics tomorrow.
Old 03-22-2016, 09:28 PM   #6
Rewards Points: 996
almost for got
each cabinet bank has one of these. the light itself can be daisy chained over to the next cabinet.
see the back corner where the wire comes out. there is a little black square, that is the sensor for the remote.
Outlets & Under cabinet lighting / wiring advice/recommendation-img_2650.jpg   Outlets & Under cabinet lighting / wiring advice/recommendation-img_2652.jpg
nutshellml (03-22-2016)
Old 03-22-2016, 09:33 PM   #7
Rewards Points: 238
THANKS! Very helpful... Any you're happy with the strip LEDs?
Old 03-22-2016, 09:52 PM   #8
Rewards Points: 996
they are GREAT !!! LOVE EM !!! we have green on for Paddies Day.
Old 03-22-2016, 09:55 PM   #9
Rewards Points: 996
oh. one thing i love about doing it this way = the transformers are off when the lights are off.
Outlets and lighting in new room jgrohol Electrical 9 06-02-2011 09:30 PM
Under cabinet lighting (Valence lighting) FredS Electrical 4 05-15-2010 10:18 PM
Under cabinet lighting direct wiring Schwarzaroo Electrical 5 12-30-2008 09:25 PM
Replacing wiring in middle of run, ungrounded lighting circuit alexz Electrical 3 07-05-2007 08:53 PM
