One More Vapor Barrier/Redgard Question - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-05-2016, 11:32 AM   #1
Rewards Points: 44
One more vapor barrier/Redgard question
We purchased a house and soon after there was a leak in the wall. The previous owners were flippers and didn't do the best work.
Fortunately, it only affected one wall on the shower. We have the same tile, grout, etc, to match.
Questions:
1. Vapor barrier or no? All I've read about the vapor barrier is that it's not needed if we use Redgard. And if I were to install vapor barrier on this wall, I'd have to cut holes in it for the piping, does that make it less effective?
2. Is there a Redgard alternative that comes in smaller quantities? All I see for Redgard seems like more quantity than I need.
Any help would be appreciated.
Here's a pic:
lrriley is offline   Reply With Quote
Old 02-05-2016, 12:19 PM   #2
Rewards Points: 144
.Redgaurd is not a vapor barrier but a waterproofing membrane.You should apply 2-3 coats to the backerboard the tile will be set on.Have only seen it in gallons around here.
What type of a backer are you using for the tile?
mako1 is offline   Reply With Quote
Old 02-05-2016, 12:48 PM   #3
Rewards Points: 44
Sorry, I wasn't clear in my question. I know that Redgard is a membrane. If I use it on top of the cement board is that enough? Or do I need the vapor as well?
And I only see it in 1 gallon here as well. Just thought 1 gallon would be too much for this small wall. It's barely 3 x 6.
And I'm using Wonderboard Lite.
Old 02-05-2016, 08:57 PM   #4
Tileguy
JazMan's Avatar
Rewards Points: 748
Redgard is TOO a vapor barrier and a waterproofing membrane and also a crack prevention membrane.
A gallon doesn't go very far and even if they made it in qts. 2 qts would cost more than a gallon.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-05-2016, 09:29 PM   #5
Rewards Points: 44
Thanks for clarifying! So in your opinion, should I do the vapor barrier (in this case a plastic sheeting) behind the Wonderboard and then the Redgard on top of the Wonderboard? Or is that overkill?
Old 02-05-2016, 09:45 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
NO NO NO! No plastic on the studs. You shouldn't do both. Apply 2 or even 3 coats on the Wonderboard, then the tiles. Be sure to use a latex/polymer modified thinset in powder form to set the tiles.
Jaz
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
