Old Grout Between Tub And Tile Wall - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-30-2015, 01:57 PM   #1
Rewards Points: 34
Old Grout Between Tub and Tile Wall
The previous owner or contractor grouted between the bath tub and tile wall then caulked over it right before putting the place on the market.
I've spent the last hour removing 5% of it.
I'm pretty sure I need to remove all the grout but maybe there is another way?
Only one full bath in this house so I need to find a solution quick.
sloth1 is offline   Reply With Quote
Old 07-30-2015, 02:13 PM   #2
Rewards Points: 144
Should have never been grouted.How are you removing it that is so hard?Have you tried one of the painters 5 in1 tools?
mako1 is offline   Reply With Quote
Old 07-30-2015, 02:16 PM   #3
Rewards Points: 34
I am removing the top layer of caulk first with a caulk tool.
Then using an utility knife, painters tool and flat head screwdriver very carefully. So far no damage to the tub or tiles.
Old 07-30-2015, 02:21 PM   #4
Retired Moderator
Rewards Points: 7,174
A carbide 'grout saw' is handy for that if the gap is wide enough.
An oscillating Multi-tool will get that done in a hurry--might not need it for one job--but they are handy for other work---so, if you need a new tool--here is an excuse to buy one.
Old 07-30-2015, 02:28 PM   #5
Rewards Points: 34
What are the cons of just caulking over the grout?
