Odd Size Kitchen Cabinets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By Colbyt
Old 01-21-2018, 07:28 AM   #1
Rewards Points: 2,184
A relative has a mobile home and would like to replace the kitchen wall cabinets. I'm having a hard time finding them.
The cabinets are 24" high. This is apparently not a size that most places stock. I would really prefer not to go the custom cabinet route ($$).
Anyone have a good source for reasonably-priced wall cabinets in odd sizes?
I've found cabinets the correct height sold for use in garages and laundry rooms, but they don't offer much selection. One stumbling block seems to be finding an inside corner cabinet. I'd need that, and a few different width options.
CaptTom is online now   Reply With Quote
Old 01-21-2018, 07:35 AM   #2
retired painter
Rewards Points: 1,352
Re: Odd Size Kitchen Cabinets
I'd retro fit it to use normal cabinets. MH cabinets are often undersized and cheaply built. How high is the ceiling?
mark sr is offline   Reply With Quote
The Following User Says Thank You to mark sr For This Useful Post:
CaptTom (01-21-2018)
Old 01-21-2018, 08:04 AM   #3
Rewards Points: 6,887
The actual size will vary depending on brand but just buy the smallest 2 door cabinet and remove one door to create a blind cabinet. I've done this more than once with wall and base cabinets.
Nealtw likes this.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
The Following User Says Thank You to Colbyt For This Useful Post:
Old 01-21-2018, 12:03 PM   #4
jlhaslip's Avatar
Rewards Points: 708
I have seen 24 inch cabinets used for bathroom vanities.
Check the size of those for your design.
Trouble would be finding corner units.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
Old 01-21-2018, 12:54 PM   #5
Rewards Points: 1,406
Maybe something here ?
http://www.homesurplus.com/mm5/merch...htdoubledoorMW
Gregsoldtruck79 is offline   Reply With Quote
The Following User Says Thank You to Gregsoldtruck79 For This Useful Post:
Old 01-21-2018, 03:08 PM   #6
Thanks all!!
The ceiling is right at the top of the cabinets. No chance of fitting a 36" cabinet.
That's my plan "B." I don't like the idea of the other door opening into the corner, but it would probably be OK if I found the right width cabinet.
Originally Posted by Gregsoldtruck79 View Post
Thanks, good link! But there's only one finish, and only 3 options for widths. Which is also the problem going with bathroom/laundry room/garage cabinets. Those don't usually have much of a selection of widths, and there's a very specific width to be covered, with only maybe 3" leeway either way on one side, and even less on the other.
I didn't mention it, but they should at least have a passing resemblance to the base cabinets, which are nearly new and won't be replaced. And before you ask, no, we don't know where they came from. I suspect they're the bathroom/laundry/garage units I see everywhere.
Old 01-21-2018, 06:27 PM   #7
Rewards Points: 1,034
Have you tried a mobile home parts store, they usually have anything you need.
https://www.google.com/search?safe=a....0.hGE-E218fKw
Canarywood1 is offline   Reply With Quote
Old 01-21-2018, 07:34 PM   #8
jlhaslip's Avatar
Rewards Points: 708
Upon re reading this Topic, I see you wanted WALL cabinets.
My mistake to suggest vanity cabinets. I was thinking about Bases.
Kindly ignore my previous posting.
Old 01-22-2018, 05:51 AM   #9
retired framer
Rewards Points: 18,492
Lower cupboard doors or often close to 24" high, Buy ready to assemble and cut them down to fit the lower doors.
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
Best paint for kitchen cabinets? W1ldC4ts14 Painting 10 10-13-2014 01:53 PM
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 07:22 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 06:31 AM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
