Is It Normal For Marble To Crack? Shower - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-06-2017, 07:58 AM   #1
Rewards Points: 4
Is it normal for marble to crack? shower
Hi,
I installed this panel in my shower last week. Last night I notice, there is a crack. I am not sure should i replace a new one or just seal it.
My wife want to replace a new one. She worry the water will cause more damage later on. Since the shower glass is not set on top yet, its easy to replace now. Cost around $350 to replace a new one.
any input are greatly appreciated!
Thanks,
Alberto
orangecounty714 is offline   Reply With Quote
Old 08-06-2017, 08:32 AM   #2
retired painter
Rewards Points: 1,328
Re: Is it normal for marble to crack? shower
It cracked because it wasn't supported properly. Either there was a void in the thinset or the base below it was uneven [maybe both] Does the liner extend under the threshold?
mark sr is offline   Reply With Quote
Old 08-06-2017, 09:12 AM   #3
Rewards Points: 4
is 2" above the shower floor and the shower glass will set on top of the marble.
Old 08-06-2017, 11:06 AM   #4
jlhaslip's Avatar
Rewards Points: 708
Yes, replace it now.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 08-06-2017, 06:02 PM   #5
Rewards Points: 898
$350 for that? HS! I'd replace them both with something cheaper.
BIG Johnson is offline   Reply With Quote
Is it normal for Gerber 3-valve shower valves to leak? Habeed Plumbing 2 09-14-2015 01:04 AM
Shower Drain -- Normal? bsmith_tsu Plumbing 2 02-03-2013 08:51 PM
Water issue in bathroom at base of the tub and shower plumbing wall NeverEnoughTime Plumbing 3 10-24-2012 11:23 PM
Shower Pan Liner in Tampa - Shower rebuild ghowmedic Building & Construction 10 12-30-2011 08:03 PM
Piece of junk, leaky shower. How can I improve it? JustinEllard Plumbing 4 10-05-2010 08:45 AM
