New Vanity Not Level - Wondering What A Pro Would Do. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By Nealtw
  • 3 Post By Tymbo
Old 05-23-2018, 01:54 PM   #1
Rewards Points: 112
New vanity not level - wondering what a pro would do.
Hi all,
installing a new vanity and unfortunately it is not sitting level. over 42" its out 1/4"
I can shim it, but worried about how it will look on the floor being up so high? It looks good as is.... is there anything wrong with being slightly out of level if it looks fine?
What would a pro do? leave as is? split the difference?
thank you!!
xyzz is offline   Reply With Quote
Old 05-23-2018, 02:03 PM   #2
Two Knots's Avatar
Rewards Points: 3,875
Re: New vanity not level - wondering what a pro would do.
Well, I'm not a pro...however, the slightly out of level would
bother me. Where is the shim needed? ... is it on the back
wall or side wall where it is not visable?
If it's visable, can you add molding on the base of the
vanity?
Joann
Two Knots is offline   Reply With Quote
Old 05-23-2018, 02:18 PM   #3
retired framer
Rewards Points: 18,390
A pro would level it every time.
MI-Roger and de-nagorg like this.
Old 05-23-2018, 03:22 PM   #4
Rewards Points: 332
If you don't want to shim it and cover the gap with shoe, you can scribe it to the floor for a clean look.
MI-Roger, de-nagorg and KC_Jones like this.
Tymbo is offline   Reply With Quote
Old 05-28-2018, 03:23 PM   #5
Home Repairer
Rewards Points: 468
Just set the vanity as is and shim the top instead. You can cover that gap with some flat molding. I am assuming that the vanity is one with "feet" instead of a traditional vanity with a toe kick. If traditional, level the vanity and cover with shoe molding.
czizzi is offline   Reply With Quote
The Following User Says Thank You to czizzi For This Useful Post:
Two Knots (05-28-2018)
Does a concrete slab floor need to be level prior to tile installation? Malcolm Flooring 9 06-03-2014 09:39 PM
How 'level' is level? BOUTYM Flooring 2 09-04-2011 05:30 PM
Vanity Tight Fit Chemist1961 Remodeling 2 01-10-2009 02:30 PM
Machining Marble SideSplash for Vanity jombres Remodeling 4 12-03-2006 05:38 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
