New Cast Iron Tub Has Discolored Marks In Porcelain - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-05-2010, 05:54 PM   #1
New cast Iron tub has discolored marks in porcelain
I purchased a new cast iron tub. The tub was kept (outdoors) but completely protected in the crate and for a few months while the remodel job progressed. There was cardboard laying in the bottom of the tub for the few months it sat.
On install date, I noticed 4 thin, dark, scratch like marks in the white finish. These marks will not come out with soft scrub, comet, 2000 grade automotive sandpaper or anything else manufacturer suggested. There is no indent so it doesn't feel a scratch. The comment cardboard burn was used by the manufacturer so I thought they may have dealt with this, but now they deny using the term. Hmmm
The manufacturer claims they can't help because the 7 day window to send back a problem item has long passed. Does anyone have an idea on how to remove such a blemish without compromising the surface? Has anyone ever heard of cardboard burn?
djfellows is offline   Reply With Quote
Old 07-06-2010, 10:09 AM   #2
Stuck in the 70's
Blondesense's Avatar
Rewards Points: 12
Do you have any vinegar on hand? Fold up a paper towel, soak it in vinegar and put it over the marks keeping it as wet as possible as long as possible. Overnight is good.
This probably won't do anything, but if you have vinegar and paper towels in the house it's worth a try. I've had good luck with this method on other stains.
pvc to cast iron hub using fernco-can't get it! What have I done Plumbing 10 01-22-2014 07:55 PM
Porcelain Quality on Steel and Cast Iron Tub? MrTubz General DIY Discussions 5 03-04-2009 05:24 AM
working with cast iron ericadami Plumbing 9 11-30-2008 12:45 PM
Porcelain on Cast Iron Tub controlnovice Plumbing 1 08-16-2008 10:36 AM
Cast iron and rusty pipe question snowens Plumbing 2 07-27-2008 10:07 AM
