New Cabinet Depth Does Not Meet Depth Of Bulkhead - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-12-2018, 10:09 PM   #1
Rewards Points: 254
New Cabinet Depth does not meet depth of Bulkhead
Hey all,
I recently upgraded my cabinets from old custom built cabinets to brand new stock cabinets, the old ones were rotting so they had to go.
There is currently a bulkhead above the old cabinets, height is not going to be an issue, and I'm covering the total difference in width with filler strips. The only issue I'm faced with is depth of the upper cabinets.
It seems the old ones were custom made to fit that kitchen, and met the bulkhead's depth perfectly, a flat trim piece was placed over the 1/16" gap between the cabinets and bulkhead.
The main issue here is that the new cabinets fall short, in other words I have about a 1/2"-1" gap where the new cabinets do not extend far out enough to meet the edge of the bulkhead (the front of the bulkhead is finished but the underneath is open framing), so this leaves a very unsightly look.
What are my options here, I will be shimming the cabinets to get a uniform measurement all around, but the gap will still be prominent
Thanks!
mbrando1994 is offline   Reply With Quote
Old 05-12-2018, 11:58 PM   #2
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 2,054
Re: New Cabinet Depth does not meet depth of Bulkhead
Finish that strip of soffit in whatever the front of it is finished in.... drywall...?
MTN REMODEL LLC is offline   Reply With Quote
Old 05-13-2018, 01:38 AM   #3
RRH
Rewards Points: 1,316
Depends on the look you want.
Put up the cabinets. Then a 1x2 trim board cut to size or quarter round molding if only 3/4". Or of course finish the drywall corner.
If you want it flush like before. Just cut nailing strips and mount to the wall first. Make the install a little easier since will not have to look for studs when mount the cabinets.
Buy the size you need or take a 2x4 and table saw and make it exact. Of course then you would just buy some pre finished trim boards that match the cabinets to cover the gap from the wall where you can see it. Or a prefinished side panel skin.
RRH is offline   Reply With Quote
Old 05-13-2018, 06:16 AM   #4
hkstroud's Avatar
Rewards Points: 5,814
Have you considered removing the bulkhead and using 36" upper cabinets. Makes a world of difference in appearance.
Harold,
The Left Handed Widget Maker
hkstroud is online now   Reply With Quote
Old 05-13-2018, 08:03 PM   #5
Rewards Points: 254
I have but the cost would blow the budget out of the water, I'm just using in store stock cabinets that are rather cheap
Old 05-13-2018, 08:04 PM   #6
Rewards Points: 254
Great idea, I always miss the simplest answer haha
Old 05-13-2018, 08:06 PM   #7
Rewards Points: 254
I've decided to install the cabinets normally and finish the corner as if it were drywall, It appears they used some type of wooden veneer or plywood to build the bulkhead nailed to the framing, but so far it has come out very nice, just have to sand the finish coat and paint. As much as I hate drywalling, I figured this would still be simpler than cutting crown/other moldings and trimming it out, which I suppose could still be done either way too
Tags
bulkhead , cabinets , install , kitchen , soffit
Cabinet hinges don't fit... arghhhh!!! pisces7378 General DIY Discussions 7 12-25-2009 07:47 PM
hanging 9" kitchen cabinet (wall) and hit air duct, no stud phunam04 Building & Construction 4 06-16-2009 10:08 PM
Under cabinet Light Suggestions jamiedolan Electrical 7 04-01-2009 11:59 AM
Under cabinet lighting direct wiring Schwarzaroo Electrical 5 12-30-2008 09:25 PM
Installing kitchen cabinet in precise manner janny Carpentry 8 01-15-2008 10:59 PM
