Neo Angle Tile Shower Install - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-07-2014, 06:20 AM   #1
Rewards Points: 64
I am remodeling a basement bathroom, removing a jetted tub, and installing a shower. Due to the layout of my bathroom I will be installing a 42 x 42 neo angle shower. I would like to create a tile floor shower, and this is my first time doing a shower (I have done plenty of bath remodels but never had to touch the shower / tub). So building a pan from scratch is over my head at this point. Drain location is not an issue as I will be moving them.
What tile ready kits are available that are good for this setup. I was going to go with tileredi but I read enough horror stories in another post to decided that was not the best plan.
I have a friend who has use the Kerdi pan, but not for a neo angle shower, which looks much more complicated.
mattlreese is offline   Reply With Quote
Old 07-31-2014, 03:27 PM   #2
DIY Veteran
diyshowers's Avatar
Shower
From what I know about TileReddi is that all your are doing is eliminating the concrete work from the job. Be sure to get a very good bond with your tile and the prefab pan otherwise you could have a mess on your hand. Voids under the tile create a breeding ground for mold and mildew. Remember that is where the dirt and moisture reside
~ Adam Harpe
___________________________________
Showers designed for the do-it-yourselfer - diy-shower.com
diyshowers is offline   Reply With Quote
Old 07-31-2014, 03:35 PM   #3
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Smile
A neo-angle shower is no different than a square shower. Build your walls, pan and curb with 2x's, cover it with cement board, float-in a cement floor or use a Schluter Systems pan-slope, then use KERDI Mat to waterproof everything. The overlaps will be a little tricky at the curb but if you can wrap a Christmas present you can wrap a neo-angle curb with KERDI Mat. Just remember the two-inch-overlap-rule when using KERDI.
Stay completely away from Tile-Redi, turn and run far far away when you see the product.
XXX
Install Tile Shower Base Drain -- Advice Needed unionmaid Kitchen & Bath Remodeling 11 12-30-2013 09:30 AM
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 07:23 AM
Must new joint compound near top of shower tile be primed before tiling? gmhut Remodeling 0 10-07-2013 10:43 AM
Sealing pebble tile before install Global37 Tiling, ceramics, marble 0 04-26-2013 10:31 PM
Anyone install Menard's Designer's Image Luxury Vinyl Tile? Studly Flooring 4 11-18-2012 07:53 PM
