Need Quick Answers! Used Grout To Adhere Tiles! - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-13-2015, 10:11 AM   #1
Rewards Points: 6
Need quick answers! Used grout to adhere tiles!
Trying to tile for the first time. Went to Lowes.......got all the supplies (well.....almost). Accidently used the unsanded grout to adhere the tiles to the backer board in our shower (most tiles put up AND grouted using the grout). Need to get them off! Job started 5 days ago and last tiles put on yesterday. Wanting to do this without damaging the tiles and backer board. Any help/suggestions appreciated.
Novice Tiler is offline   Reply With Quote
Old 12-13-2015, 10:14 AM   #2
ZZZZZ's Avatar
Rewards Points: 2,146
Are you talking about the shower walls or floor (or both)?
ZZZZZ is offline   Reply With Quote
Old 12-13-2015, 10:23 AM   #3
Rewards Points: 6
Shower walls
Old 12-13-2015, 11:27 AM   #4
Retired Moderator
Rewards Points: 7,174
You might be okay leaving it as is---------is the work showing signs of failure?
As to removing the tiles and reusing them----not to likely---they may pop right off, but they might just break up---or pull hunks out of the backer.
Novice Tiler (12-13-2015)
Old 12-13-2015, 11:43 AM   #5
Rewards Points: 6
Thank you. We are right in the middle of the project so we don't yet know if it's a fail yet..... Panicked when we realized we were using grout. Wasn't sure the grout would hold the tiles (especially in such a damp environment as a shower.)
Old 12-13-2015, 02:22 PM   #6
Tileguy
JazMan's Avatar
Rewards Points: 748
Unsanded grout should work if the tiles are soft bisque ceramic. I'd probably leave them alone after trying to remove a few and they don't just pop off, unless it's just a small area done by mistake. They're probably stuck pretty good.
What were you intending to use?
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
The Following User Says Thank You to JazMan For This Useful Post:
Three Year Old Fireplace - Cracking Grout & Loose Tiles! NickGriffith Tiling, ceramics, marble 0 05-12-2014 08:12 PM
Caulk or Grout on Cap Tiles papageek Kitchen & Bath Remodeling 6 08-24-2012 11:23 PM
I need to buy grout and tile spacers. What is the most common space between 6x6 tiles sukhenkoi Kitchen & Bath Remodeling 6 05-02-2011 07:42 AM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 08:40 PM
Removing film from tiles after using Bostik premixed grout J Hemmens Kitchen & Bath Remodeling 1 08-24-2010 08:10 PM
