Need Lots Of Help-kitchen Remodel - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 08-11-2015, 10:12 PM   #1
Rewards Points: 33
Need lots of help-kitchen remodel
If you look at the pics, there is a plastic ceiling tile that I want to remove. Also, there is a ventilation system that goes directly outside and would be exposed if I removed the tiles. So how do I go about that. Also, you can see the holes in the walls above the tiles that are patched up with wires coming from there. What would be in there and would I be able to patch and paint that? Need help here lol
Elton20 is offline   Reply With Quote
Old 08-11-2015, 11:04 PM   #2
Rewards Points: 5,348
Remove what you want to remove.
I'd have an electrician handle the wiring as it needs to be identified and removed or rerouted properly. It sounds like you have no experience with the wiring aspect of the job.
Once that happens you can patch the holes.
Ron
B. Franklin 1759
Old 08-12-2015, 12:01 AM   #3
Rewards Points: 33
Ok. So I patch the duct hole and then just buy a ductless range hold?
Old 08-12-2015, 12:02 AM   #4
Rewards Points: 33
Hood
Old 08-12-2015, 06:36 AM   #5
Retired Moderator
Rewards Points: 7,174
You may need to open up that drywall in order to route the exhaust duct behind it---
If that is not an option due to obstructions--a soffit could be built to hide the ducting.
Old 08-12-2015, 07:08 AM   #6
craig11152's Avatar
Rewards Points: 1,216
Is there a 2nd floor above or attic space?
also you can get some pretty nice looking drop ceiling panels these days. You might have to add some track or reposition some...just a thought.
Don't look at me. I didn't vote for either one of them.
craig11152 is offline   Reply With Quote
Old 08-12-2015, 07:28 AM   #7
GrayHair's Avatar
Rewards Points: 1,336
I did a lot of work in commercial kitchens with drop-ceilings and panels, other than lighting, were 5/8" sheetrock. If you consider doing this, don't forget the weight. A 2'x4' panel of 5/8" sheetrock weighs 15-20 pounds, so make darn sure the grid is well supported. A coat or two of paint (fully dry) appropriate for a kitchen environment would ease future cleaning.
Any mention of codes is based on NFPA 70 and/or 72, as applicable, because they are the most widely adopted codes in the US. Local amendments may modify the code adopted in your area, so consult your local codes official.
GrayHair is offline   Reply With Quote
Old 08-12-2015, 09:19 PM   #8
Registered User
Rewards Points: 526
To others reading; do not use a bath fan with plastic coated FLEX duct (3"-4" rather than 6-7" smooth metal pipe or rectangular metal duct) in a kitchen for grease....
Gary
Old 08-13-2015, 08:26 AM   #9
Rewards Points: 33
Oh, I was just wanting to get the original height of the ceiling. There is an attic where I would be able to install duct work and the recessed lights
How to remodel Kitchen johnsorious Remodeling 13 07-01-2013 04:29 PM
kitchen remodel... color question(s) Rkn Interior Decorating 11 02-01-2013 10:58 AM
Kitchen remodel leiona Project Showcase 251 10-04-2012 09:58 AM
Kitchen remodel and venting joeh Plumbing 5 12-17-2011 06:38 PM
Kitchen remodel; ductwork pinkertonpv HVAC 3 02-18-2009 03:03 PM
