Need Help. TileRedi Not Sloping Into The Drain - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 07-30-2017, 04:59 PM   #1
Need help. TileRedi not sloping into the drain
I have installed a TileRedi 36 x 36 center drain shower base. I leveled all four sides but when I tested the slope with water, one corner had a pool of water. I have not put the provided epoxy or laid any tiles. I wanted to know if there is any remedy to deal with the improper slope on one corner to ensure proper drainage.
Lilian
Lilian t is offline   Reply With Quote
Old 07-30-2017, 05:54 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Re: Need help. TileRedi not sloping into the drain
There is probably not a great deal of slope on the pre manufactured unit. Once you have it fastened in place you will begin to tile. Keeping a level handy, increase the thinset slightly to the side that needs elevation. Not much. Just enough to allow the tile to be at a slope indicated all the way around the base.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-30-2017, 06:49 PM   #3
Thank you Chandler48. The company gave me epoxy to lay the shower floor tile. I don't know the consistency of it but would the same rule apply for this?
Old 07-30-2017, 07:10 PM   #4
Naildriver
chandler48's Avatar
Ouch, probably not. Unless it is the consistency of thinset. Is it epoxy "grout" or is it specified as a product to lay tile with? I don't understand if you have the unit level, why one corner is high, unless it was molded improperly.
Larry......
Old 07-30-2017, 09:14 PM   #5
I'm not quite sure. It's a 3 part mix and doesn't note or refer is as grout
Old 07-30-2017, 09:15 PM   #6
But here is the residual water. Is it a big issue?
Old 07-31-2017, 05:32 AM   #7
Naildriver
chandler48's Avatar
Can you link us to the product?
Larry......
Old 07-31-2017, 05:53 AM   #8
retired framer
Rewards Points: 18,598
http://www.homedepot.com/catalog/pdf...3c4e48c4d8.pdf
Old 07-31-2017, 04:51 PM   #9
Naildriver
chandler48's Avatar
So it is more the consistency of Acrylpro or other mastics, as opposed to thinset?
Larry......
Old 07-31-2017, 09:37 PM   #10
firehawkmph's Avatar
Rewards Points: 2,452
The epoxy from Tileredi is an epoxy thinset, not a grout. I don't think you'll be able to build it up at all to get rid of your puddle. It is very tacky though, and smells.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Condensate Drain Line & Pan Problems hobbzilla HVAC 10 08-04-2014 11:31 AM
What is this thing?? Todd54 Plumbing 10 05-09-2012 04:18 AM
Avoiding a frozen paver drain BrandonC_1972 Plumbing 2 04-28-2012 09:11 AM
Slow and clogged shower drain help COBRA90GT Plumbing 9 12-22-2009 02:25 AM
relocating washer drain idodishez Plumbing 7 04-21-2009 08:36 PM
