Need Help Laying Out Recessed Lights... - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-22-2017, 01:57 PM   #1
Rewards Points: 20
Need help laying out recessed lights...
Hi all,
I have a bit of an odd shaped bathroom. It is roughly 15 feet long, and the width is a bit variable (See image below) The image is to scale as best as I could ... There will likely be shelves to the right of the toilet, 6 inches or so in depth. There may be a cupboard to the left of the shower along the top wall.
I am in the process of gutting and redoing it from studs up, and I'm trying to figure out what would make sense as a layout for 3.5 inch recessed lights in the ceiling. As you can see in the image, I will have a 4 light vanity light, as well as a 6 inch waterproof recessed light in the shower.
That leaves me with the rest of the bathroom. There are two doors and a window (also on image). Any suggestions as to where I should place the lights? The number of lights isn't a huge issue for me, as long as they're in some kind of a logical layout and will provide good lighting for the whole bathroom. These are 45 watt equivalent LED soft white lights, if that makes any difference. They are IC and wet rated, so can be put anywhere right into 3 inch holes in the ceiling drywall.
Hoping someone can give me some good advice, I don't want it to look all willy nilly.
Jax2 is offline   Reply With Quote
Old 11-22-2017, 04:22 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,652
Re: Need help laying out recessed lights...
I don't think you will need much more if you were to use LED's. Maybe a couple equidistant from the door wall and the shower edge. I would separately switch everything as you probably wouldn't need the vanity light on if you are just going to take a shower. But that would be a personal call (ergo. wife)
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 11-22-2017, 05:20 PM   #3
jlhaslip's Avatar
Rewards Points: 708
That light above the shower could be a Heat Lamp on a timer switch.
Short of cutting off a body part, the worst that can happen in woodworking is manufacturing really nice looking kindling. --- Quoted from lenaitch
jlhaslip is offline   Reply With Quote
Old 11-24-2017, 08:13 AM   #4
Rewards Points: 996
45w led's are not very bright. i would put at least 4 down the center
Fix'n it is offline   Reply With Quote
I installed recessed lights in my kitchen... I have some questions. Ler0y Jenkins Electrical 4 11-07-2013 01:50 PM
Recessed lights: What are the differences between LED trims and LED modules? htabbas Electrical 7 11-27-2011 10:54 AM
Need info on replacing 8 recessed lights in bathroom OhmZoned Electrical 1 11-07-2011 12:35 PM
help installing wall and recessed lights. nancyT Electrical 4 09-15-2010 01:58 AM
Recessed lights, wiring, breaker buzzing, etc diyguy999 Electrical 3 12-21-2009 01:10 PM
