Must Drywall Be Primed Before Adhering Tile? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree2Likes
  • 1 Post By chandler48
Old 08-16-2018, 06:05 PM   #1
Rewards Points: 110
Must drywall be primed before adhering tile?
If so why is this step necessary?
provlima is offline   Reply With Quote
Old 08-16-2018, 07:57 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,130
Re: Must drywall be primed before adhering tile?
What about RedGard?
TarheelTerp is online now   Reply With Quote
Old 08-17-2018, 05:13 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,640
IF it is a wet area, you should not be using drywall at all. If it is a backsplash in a dry area, then it should be primed. Priming helps to make the drywall paper more adaptable to receive the tile.
mark sr likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 08-17-2018, 05:13 PM   #4
Rewards Points: 917
[QUOTE=chandler48;5610333]IF it is a wet area, you should not be using drywall at all.
Drywall is acceptable substrate in a wet area but needs to have a moisture barrier applied. RedGuard and Kerdi are two examples.
Also needs to be 3/4" to support the weight and provide structure for tile. Don't use green board, use regular drywall because the waxes in green board can interfere with adhesion.
chiraldude is offline   Reply With Quote
Old 08-17-2018, 05:39 PM   #5
Naildriver
chandler48's Avatar
Sort of negates itself in cost alone, so why not just go with cbu in the wet areas?
mark sr likes this.
Larry......
Drywall seam over door not screwed in... Pioneer Wife Drywall & Plaster 25 06-02-2018 09:46 PM
Shower tile on drywall pisbouts Tiling, ceramics, marble 2 11-18-2012 11:32 AM
Can I install Kerdi over primed drywall in a basement bathroom? Mechelle Tiling, ceramics, marble 13 04-22-2012 10:50 AM
Ceramic Tile on Drywall fisher501 Flooring 3 03-20-2011 04:48 PM
mixing tile and drywall rocketdoctor Drywall & Plaster 1 10-09-2009 12:17 PM
