Mounting Floating Vanity Onto The Tiled Wall? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-06-2019, 06:18 PM   #1
Rewards Points: 650
mounting floating vanity onto the tiled wall?
I'm getting ready to work on our guest bathroom that calls for tiling the whole wall. We're installing 27" wide floating vanity. Do I tile the whole wall and then install the vanity over the tile or do you plan on where the vanity will be and not tile that area so the vanity rest against the sheet rock?
What I'm concerned about is the vanity cracking the tile.
dannieboiz is offline   Reply With Quote
Old 04-06-2019, 06:26 PM   #2
retired framer
Rewards Points: 4,714
Re: mounting floating vanity onto the tiled wall?
I don't see the need for tie behind it. If it will be in the way for tiling bolt it up and solve all those problems outline it with a pencil, take off and tile.
Do not use flat bottom gables with scissor trusses.
Old 04-06-2019, 06:29 PM   #3
Rewards Points: 650
It would actually be less work to tile it all the way up, my tiles are very large pieces 13x39. It'll be less cutting if I did it all the way up. Does it matter then?
Old 04-06-2019, 06:33 PM   #4
retired framer
I best leave that answer to people who have done it.
The wall would have to be flat so you aren't moving the wall to flat with the vanity.
Old 04-07-2019, 09:35 AM   #5
Rewards Points: 1,840
Would you rather put up your tiles and then drill holes through them, or just cut them before you put them up? I know which I'd rather deal with.
huesmann is offline   Reply With Quote
Floating Vanity Brackets won't adjust FastEddie26 General DIY Discussions 1 07-10-2017 10:53 AM
Finding solid wall behind tiles to mount pedestal sink! miamicuse Building & Construction 2 06-19-2016 07:23 PM
How to fix gap behind vanity due to Uneven Wall MRT888 Kitchen & Bath Remodeling 8 05-28-2016 08:16 AM
Mounting 60" LCD to thin concrete wall flatblackstrat Concrete, Stone & Masonry 7 02-18-2013 08:21 PM
