Mosaic Tiles - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-30-2014, 08:25 AM   #16
Rewards Points: 5,698
Even though it doesn't specifically say on the pail it can be used for glass mosaic, it should really be fine, since they have a mesh backing and won't be getting much wear and tear.
I just scanned my previous post and have a change to make - I said you might want a product such as Grout Once. I didn't realize you had some stone tiles in there. I would recommend a standard sealer such as Miracle 511 with the stone tiles. Put one coat on the stone tiles before grouting, and after grouting put a coat over everything. (Obviously it won't soak into the glass, but just wipe it all up after soaking into the grout and stone.)
jeffnc is offline   Reply With Quote
Old 01-17-2015, 07:49 AM   #17
Rewards Points: 1,176
I asked the question to Custom Building Products, and this is what they answered:
Thank you for your interest in Custom Building Products. It is recommended to follow the tile manufacturers recommendation. Customís Glass Tile Mortar is a very white latex modified thin-set, it is available at Home Depot.
Mastics will bond your Mosaic Tile. However they can turn glass tile yellow and discolor some types of stone.
If you require further assistance please, let me know.
Looks like the only risk is discoloration???
What do you guys think?
Not having to do the mix is a big plus for me........
french_guy is offline   Reply With Quote
Old 01-17-2015, 08:19 AM   #18
Just to be more clear, mastics won't turn your glass yellow. What they will do is yellow themselves over time, showing through the glass.
Old 01-17-2015, 08:48 AM   #19
So since back of tiles are glazed, I should be fine then?
Old 01-17-2015, 08:51 AM   #20
You should be. It would be different if you were using a porous natural material such as marble. Glass is impervious and can't absorb anything.
how should I install these mosaic tiles oldhouse49 Tiling, ceramics, marble 16 06-19-2014 12:43 AM
Best way to cut mosaic tiles for backsplash pdp76 Concrete, Stone & Masonry 7 04-16-2013 11:29 AM
Kitchen backsplash - mosaic tiles mikeyp78 Tiling, ceramics, marble 11 09-30-2012 08:39 PM
Mosaic tiles Breakthecycle2 Flooring 20 06-27-2011 04:26 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 06:10 PM
