Mortar Recommendation For RedGard Coated Tile Backer - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree8Likes
Old 01-21-2019, 12:52 PM   #1
Rewards Points: 144
Question
Mortar recommendation for RedGard coated tile backer
Hi Guys,
I'm renovating my bath and installed Greenboard around the tub. Now about to mud/tape/seal joints and apply RedGard water membrane. Now my question is .. I'm getting different opinions what mortar I should use. Some say use unmodified because of Kerdi niche, some say modified.
I understand the reasoning behind both but since RedGard is the last layer over everything (actually 3 layers as I need it to be really waterproof) ... should I just follow RedGard recommendations?
What would you use to tile? Any product recommendations?
BTW I have porcelain 4x12 tiles.
Thanks for Your advice.
misuszatek is offline   Reply With Quote
Old 01-21-2019, 02:37 PM   #2
Naildriver
chandler48's Avatar
Rewards Points: 3,592
Re: Mortar recommendation for RedGard coated tile backer
Is there a good reason why you chose to use greenboard in a wet area?
powerlifter405 likes this.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 01-21-2019, 03:00 PM   #3
Rewards Points: 144
I was looking for something manageable as far as cutting, weight, install etc. Normally CBU would be my first choice but I needed something easy/quick. Going full Schulter crossed my mind but Greenboard with RedGard is faster / easier / less expensive.
The old (removed) setup was tile over drywall and lasted previous owners for 40 years without even one leak ... If this with a proper barrier will last 20 I will be glad. By then my tiles will be ugly anyway :D
Old 01-21-2019, 03:53 PM   #4
Rewards Points: 1,272
It's a trick question - the answer is NO !!!
195795 is offline   Reply With Quote
Old 01-21-2019, 03:55 PM   #5
Tear it all out and do it right with CBU and loose the kerdi too, you don't need it
Old 01-21-2019, 04:34 PM   #6
Naildriver
chandler48's Avatar
Let's see greenboard runs about $15 a sheet and you would need 3, so $45. Redgard will cost about $60 per gallon, and you may get it covered with a gallon, not sure, so now it's up to $105 your way.
CBU runs $14 per sheet and you would need 4, so that's $56. You don't need to Redgard cbu.
Nothing difficult about cutting cbu.
Miss one pin hole with your Redgard and it will tell on you in short order using greenboard.
Larry......
Old 01-21-2019, 06:37 PM   #7
Interesting, you guys don't use RedGard on CBU ? We do on all jobs
firehawkmph and ZZZZZ like this.
Old 01-21-2019, 06:43 PM   #8
Naildriver
chandler48's Avatar
I use it on cubbies, and in corners, but let the thinset and tape do the job on the flat surfaces. I've only done one entire walk in shower from ceiling to floor, including the floor in RedGard, but the customer specifically requested it. I just don't think Redgard on this greenboard will have long lasting effects, especially if he misses a spot and water can eke through.
Larry......
Old 01-21-2019, 06:53 PM   #9
Definitely the green board is a bad idea - I don't think he'll take the advice and will stay with it and RedGard over it, big mistake but live and learn I guess right, it's his project.
We only use CBU with 2 coats of RedGard or we don't do the job.
Old 01-21-2019, 07:53 PM   #10
Rewards Points: 2,438
Esp gypsum board that close, or touching the tub. That joint, and the corner, almost always cracks. I grout then cover with silicon caulk. Caulk keeps the cracked grout from falling out.
If you can, cut about 3/4 of the board away from the tub surface. Fill this with tile glue or thinset as you tile.
Modified means it has acrylic extra in the thinset. Not more special than that. Acrylic makes it more sticktuitive and bit more water resistant. I think modified is recommended for marble or such that could warp from straight water mixture as well as more sticky. Ask google, "why use modified thinset?" Depends on the tile you're using but you can make the similar thinset by using admix (name?) and water to mix your thinset. But this kind of thinset or grout is harder to clean away if allowed to dry too much. You can also use glue, if your tile is not that heavy. I used whichever over redguard. I don't think redguard is incompatible with any of the building adhesives.
carpdad is offline   Reply With Quote
Old 01-22-2019, 06:27 AM   #11
Rewards Points: 52
Not a pro - just have done a 4 showers. (3 of them the same one over a 20 year period - so I have had to correct my mistakes and see the results. Green board is useless in a wet area.
I don't think Redgard is approved (by them) to adhere to Green board, because of the makeup of green board. I would check with them before proceeding. It they say its OK you may have a shot with 3 careful coats.
CB with Red guard (or similar) over it is the way to go for DIY.
If i was the OP - I would cut out the bottom and replace with CB. Even 3 feet would help a lot.
tribe_fan is offline   Reply With Quote
The Following User Says Thank You to tribe_fan For This Useful Post:
misuszatek (01-22-2019)
Old 01-22-2019, 07:56 AM   #12
Rewards Points: 144
Originally Posted by Texasdiyer View Post
I don't think he'll take the advice and will stay with it and RedGard over it...
You "don't think" based on what exactly? I'm here for advice so it would be counter-logical to work against it while seeking it at the same time
I picked a greenboard because I had plenty already delivered and came across this video when starting work on the bath. Seems easy.
When I will go with CBU I will definitely cover it with RedGard ... it puzzles me why some would use CBU without it if you go all the way with CBU already.
Anyway..BACK TO ORIGINAL QUESTION:
Assuming CBU is on the wall with coats of RedGard.... whats next? / which product you would recommend for tile install? (I have porcelain 4x12" with 2mm groutline / have leveling system)
Old 01-22-2019, 03:43 PM   #13
Rewards Points: 52
I'm pretty sure I used Versabond modified thin-set from Home Depot. (The kind you mix) I was sure I saw that Redgard specified modified, but can't seem to find it in their specs.
Old 01-22-2019, 04:12 PM   #14
firehawkmph's Avatar
Rewards Points: 2,452
The green board would be fine with just kerdi over it. Why not just do that since you already have the kerdi nitch? No need for redguard then. Trying to mix systems is not a good idea. Go with one or the other. kerdi is very easy to use, like wallpapering.
Mike Hawkins
firehawkmph is offline   Reply With Quote
Old 01-22-2019, 06:25 PM   #15
"You don't think I will based on what exactly?"
Based on the fact that you put up green board in the first place
If you're seeking advice why didn't you seek advice on using green board vs. CBU before you put it up ?
Mortar under tile remains wet--why? chemdawg Tiling, ceramics, marble 3 10-17-2016 06:55 PM
Mud the backer board joints before tile? Firefighter3244 Tiling, ceramics, marble 29 05-28-2016 03:11 PM
Remove tile fabric and mortar? Shpigford Flooring 5 02-09-2013 04:59 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
