Mold Resistant Sealant? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 03-06-2016, 04:43 PM   #1
Rewards Points: 67
Mold resistant sealant?
Hey guys I would like to redo my sealant in one area around my bath tube where mold has become a problem. Can someone please recommend a sealant that is best for preventing mold?
Thanks!
tate16t is offline   Reply With Quote
Old 03-06-2016, 06:53 PM   #2
Rewards Points: 17,882
Most often the mold is not the caulking's fault.
Need more info.
Tiled wall?
If so what condition is the grout in? Drywall behind it instead of tile board?
When's the last time it was sealed?
Is there an exhost vent and it being left on long enough?
Old 03-06-2016, 07:41 PM   #3
Rewards Points: 67
Need more info.
Tiled wall?
Thanks for your response..
Tiled wall? -- No, , it's the bottom of a glass shower were the track meets the tub. Only one section nearest to the shower head where water collects most.
If so what condition is the grout in? -- No grout
Drywall behind it instead of tile board? NA
When's the last time it was sealed? 6yrs ago when I installed the glass door.
Is there an exhaust vent and is it being left on long enough - yes and I believe so.
I also had mold collect around the bathroom sink, on the sealant itself as well.
Old 03-06-2016, 08:05 PM   #4
Super Moderator
Gymschu's Avatar
Rewards Points: 6,734
There's really no such animal........like mold resistant "sealant." Anything that gets wet and stays wet, is an environment for mold growth. I suppose a silicone caulk gives you the best chance at keeping mold at bay, but, in reality, keeping things dry is your best hope. If you replace the "sealant" be sure to dig all of the old out with a putty knife, make sure it's bone dry, and reapply some "sealant" which in this case should be silicone, one of the rare times it warrants usage.
"In the heat of battle, my father wove a tapestry of obscenity........."
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
joecaption (03-06-2016), tate16t (03-06-2016)
Old 03-06-2016, 08:16 PM   #5
Main reason it would mold up is if it was appied wrong.
There's lots of mold resistant silcone resistant caulking avalible.
If it's blobbed on and not appied on a super clean surface and only enough to to fill the gap waters going to get behind it and mold up.
Got a picture?
tate16t (06-09-2016)
How to control Mold Part 1 Maintenance 6 How To Guides 18 05-01-2017 09:17 AM
Dens Armor vs Mold Resistant drywall in basement? Solaritu Drywall & Plaster 0 05-07-2015 05:51 AM
Need mold resistant bath sealant with color! darsunt Kitchen & Bath Remodeling 2 03-09-2015 09:48 PM
Sheetrock in bathroom. Need a mold resistant joint compound? vestaviascott Drywall & Plaster 2 12-17-2014 03:30 PM
Mold found - unsure what to do?? izzyant88 General DIY Discussions 12 06-17-2011 06:21 AM
