Metal Trim For Tiled Inside Corners - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2018, 09:35 AM   #1
Rewards Points: 252
Metal trim for tiled inside corners
I have a question. In the past, I have always tiled to the corners and used a sanded caulk instead of grout to prevent cracking. However, I was wondering if it would be advisable to use a metal corner instead and just tile up to that, therefore eliminating the chance that I will have to recaulk after a few years.
Any advantages/disadvantages to this? Shower will use kerdi membrane and tile is 4x16 ceramic subway.
1995droptopz is offline   Reply With Quote
Old 01-04-2018, 10:14 AM   #2
Guapo
Rewards Points: 11,950
Re: Metal trim for tiled inside corners
http://fmsiguila.com/wp-content/uplo...ap-687x941.jpg
I would look for ceramic before metal. The only problem is how it gets attached.
Guap0_ is offline   Reply With Quote
Old 01-04-2018, 12:49 PM   #3
Rewards Points: 1,406
Outside corner or inside ? If you are proposing putting a 90 degree metal piece in the corner, then butting your tile to each "leg" of the metal, you have just added another vertical joint. The grouted or caulked inside corner = just one joint to deal with.
To me, nothing works better than sanded, color matching caulk used on inside corners. When just using grout, it seems the grout will eventually crack. JMO
Gregsoldtruck79 is offline   Reply With Quote
Not tearing fiba fuse inside corners ponch37300 Drywall & Plaster 5 10-10-2016 10:08 AM
New Roof but Fascia Trim Board Rotting ein0801 Roofing/Siding 6 07-15-2012 12:21 AM
Paper Faced Metal Corner Bead & Multiple Intersecting Corners Fire4Effect Drywall & Plaster 2 04-09-2012 09:53 PM
Paper faced Metal inside/outside corners? slinku2020 Remodeling 6 03-20-2009 10:16 PM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
