MDF Or Plywood? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-14-2015, 11:52 AM   #1
PPBART's Avatar
Rewards Points: 1,243
MDF or Plywood?
I would like some real-world opinions from folks who have experience building laminate countertops... I've read/heard recommendations to use MDF for the countertop, and I've read/heard recommendations to use plywood. Which would the pros prefer? If plywood, what species/grade?
PPBART is offline   Reply With Quote
Old 06-14-2015, 12:27 PM   #2
Rewards Points: 17,890
Never once heard of anyone using MDF, more likly partical board.
I only use A/C subfloor grade plywood.
Partical board gets wet once and and it turns to oatmeal.
Do you already have all the tools to do this job?
Taken a look at the counter tops sold at Home Depot that have a Roman Ogee edge on the front and on the back splash?
I spent less for them then I could have made them for.
ddawg16 (12-05-2015)
Old 06-14-2015, 12:32 PM   #3
Plumber
TheEplumber's Avatar
Rewards Points: 706
This thread may help some--
http://www.diychatroom.com/f98/how-b...tertop-166320/
Old 06-14-2015, 06:11 PM   #4
PPBART's Avatar
Originally Posted by joecaption View Post
Never once heard of anyone using MDF, more likly partical board. I only use A/C subfloor grade plywood...Do you already have all the tools to do this job?...
Not advocating for either, but I've read that MDF is a higher grade of material than particle board, made of finer wood fibers mixed with resins and glue and compressed under high pressure. Supposedly it is much more resistant to moisture. I've also read that MDF is recommended as a substrate for laminate counter tops as it is smooth, flat, very dense and takes rubber cement well. Of course, that same density means it's heavy(!) I've used it for a couple of small projects so far, but think I'll use plywood for some others. I do have all the tools needed for the job.
Old 12-03-2015, 01:29 PM   #5
Rewards Points: 4
when I was building my own laminate countertops all I would use was industrial grade particle board because that's all Wilsonart would honor a warranty on. Some of the other laminate manufacturers might be different.
jocko165 is offline   Reply With Quote
Old 12-03-2015, 03:46 PM   #6
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,486
They must have added that in the last few years, they never had that in their warranty before.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-05-2015, 08:31 AM   #7
Rewards Points: 4
BigJim, this is what I was told by my Wilsonart rep. I had the same questions myself. The man that taught me how to build cabinets and countertops always used plywood. So when I opened my own shop I asked my rep and that is what she told me. I know some people don't like pb because it is so bad when it gets wet, I feel the same way. I hate the stuff. but when plywood gets wet it has issues too. It just takes longer. I always made sure I caulked any joints really well and told my customers to make sure plumber sealed real good around sinks. If it stays dry it works great
The Following User Says Thank You to jocko165 For This Useful Post:
BigJim (12-05-2015)
Old 12-05-2015, 09:36 AM   #8
JOATMON
ddawg16's Avatar
Rewards Points: 9,252
Considering they tell you not to use MDF in wet locations like a bathroom, I'm surprised anyone would want to use MDF for a counter top. It's basically compressed paper.
Staples or screws on plywood subfloor? And other questions.... howdihi Flooring 1 08-18-2011 08:50 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
It is hard to find 1/2 t and G plywood so would regular plywood be ok ? dewi Flooring 14 05-04-2010 12:05 PM
Tile over plywood? Thurman Flooring 3 07-12-2009 09:05 AM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
