Low Profile Shower Curb - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-04-2016, 10:02 PM   #1
Rewards Points: 2
Low profile shower curb
I want to install a low shower curb. Why is it that every "pro" uses 4"+ for a curb height? I would like to minimize the step over and use a 2 x 4 set flat on the floor. then the built up height would be 2" or so. Why not? The door has a sweep, water is not directed at the bottom. I have tile os so not worried so much about wet floor. I do not have enough drain pipe depth to allow a no curb.
tigerr is offline   Reply With Quote
Old 01-04-2016, 10:10 PM   #2
Rewards Points: 1,002
I would avoid using lumber. If you want a 2" high curb, just cut down some brick to 2" minus the thickness of your tile, the thinset under the tile, and the thinset under the brick.
If you don't like that idea, just use 3 layers of 1/2" tilebacker, stacked.
cleveman is offline   Reply With Quote
Old 01-05-2016, 11:37 AM   #3
Rewards Points: 52
Don't quote me as I'm not sure if local codes differ - but I think the minimum is 2 inches above the drain. I stayed in a condo in Florida that did not even have a curb.
tribe_fan is offline   Reply With Quote
Shower Head (over head) dripping while using Hand Held Shower Head HTFreak Plumbing 14 09-29-2015 03:46 PM
Shower Panel Install Gone Wrong Bushido_Ben Plumbing 10 11-03-2013 07:23 AM
Curb for shower is close to heater, how to proceed? RyanD Building & Construction 6 01-19-2013 11:13 AM
Thinset over lath on shower curb? darsunt Remodeling 0 01-01-2013 11:03 PM
shower pan curb califmonster Building & Construction 2 07-31-2011 08:34 AM
