Loose Shower Head Pipe Fix, Help Needed - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree4Likes
Old 06-28-2018, 01:07 PM   #16
retired framer
Rewards Points: 18,478
Re: Loose shower head pipe fix, help needed
Just smooth it out over a larger area.
Nealtw is offline   Reply With Quote
Old 06-28-2018, 05:06 PM   #17
Great, thanks. I'm put another coat tonight but this time over later area and let it dry fit couple of days before I send it. Should I dry or wet send it?
Sent from my SM-G955U using Tapatalk
daniel600x is offline   Reply With Quote
Old 06-28-2018, 05:21 PM   #18
retired framer
Scrape lumps off before adding filler, try to get it smooth so you have little sanding. I dry sand. I have seen people finish with wet sponge after dry instead of sanding but I never had any good results.
The Following User Says Thank You to Nealtw For This Useful Post:
daniel600x (06-28-2018)
Shower Head mounted on glass wall? Superdave777 Remodeling 3 04-11-2017 08:21 PM
water from the center of a shower head mmhendrie Plumbing 4 09-25-2013 06:01 PM
help re-installing shower head 1/2" pipe extension cbons Plumbing 2 04-15-2009 05:06 PM
Adding a second shower head? J187 Remodeling 6 03-26-2009 11:16 AM
Stuck shower head stealthxcat Plumbing 1 05-08-2007 09:19 PM
