Leveling Bathroom Vanity Using Shims - OK For Long Term? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree5Likes
  • 2 Post By Nealtw
  • 1 Post By Yodaman
  • 1 Post By XSleeper
Old 02-07-2018, 01:51 PM   #1
Rewards Points: 136
Leveling Bathroom Vanity using shims - OK for long term?
I'm putting in a new bathroom vanity in my rental unit and I leveled it using wood shims. It's perfectly level, but is this actually OK to do? Bathroom can have water spills on the wood or just general moisture from humidity.
Unsure if I should paint the shims with BIN for protection? Using some sort of plastic shim/spacer?
WalkThisWhey is offline   Reply With Quote
Old 02-07-2018, 02:19 PM   #2
retired framer
Rewards Points: 18,758
Re: Leveling Bathroom Vanity using shims - OK for long term?
Now you are over thinking it. You can buy plastic shims if you are really worried about it.
Yodaman and WalkThisWhey like this.
Old 02-07-2018, 02:55 PM   #3
Property Mgt/Maint
Rewards Points: 6,374
Forget painting shims, put a bead of caulk around the base of the cabinet. If the gap is too big maybe molding is in order, then caulk around that.
WalkThisWhey likes this.
Yodaman is offline   Reply With Quote
Old 02-07-2018, 03:16 PM   #4
Rewards Points: 136
Thanks guys! Glued them together and i'll be running some caulk at the end
Old 02-07-2018, 03:25 PM   #5
Rewards Points: 1,265
If the vanity is going on top of a finished floor where you would otherwise see the shims, you can also scribe (cut) the bottom of the vanity to match the floor, rather than using shims.
Nealtw likes this.
XSleeper is offline   Reply With Quote
Old 02-07-2018, 03:28 PM   #6
Property Mgt/Maint
Yea, I have watched Norm on TOH trim cabinet bases, but does anyone really do that? Very few I would guess, but it is a option.
Old 02-07-2018, 03:36 PM   #7
You do it when you have to. For example a bathroom that is already tiled gets a slightly larger vanity. It has to sit on top of the tile, so if the floor is out of level, it's a good move to cut the vanity rather than shim it. Same goes for vanities with legs that sit on tile.
jlhaslip likes this.
Bathroom Vanity, Baseboard, Backsplash question FastEddie26 Kitchen & Bath Remodeling 2 01-18-2015 01:29 PM
Vanity light bathroom drill hole concern sooner2k1 Plumbing 1 01-10-2008 07:04 AM
Bathroom Vanity Lights... after GFCI? CuCullin Electrical 4 11-12-2007 03:16 PM
Bathroom vanity rough in diyer4162 Carpentry 13 11-09-2007 05:36 PM
Adding outlets behind bathroom vanity? Carwen Electrical 3 08-14-2005 09:10 PM
