Leveling Acrylic Shower Base On Concrete - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-08-2017, 05:26 PM   #1
jkk
Rewards Points: 317
Leveling acrylic shower base on concrete
I have 1/2" slope on finished concrete basement floor where shower base will be. I could 1) flatten the area now and then place base later using additional mortor, or 2) get the drain ready now, place enough mortar to level AND fill in grid under base. #2 obviously quicker and less mortar mixing but worried about not keeping base level.
Suggestions? Thanks.
jkk is offline   Reply With Quote
Old 12-08-2017, 09:17 PM   #2
Guapo
Rewards Points: 11,950
Re: Leveling acrylic shower base on concrete
I would shim the pan with mortar. Are you going to install an ejector pump? Is the sewer line below grade?
Guap0_ is offline   Reply With Quote
Old 12-08-2017, 09:22 PM   #3
Rewards Points: 6
Just a couple thoughts here...
Could you make sure your drain pipe is all set, buildup the mortar bed up then push the shower pan into the mortar, then level out before it sets? Or level out with mortar/leveling compound and then use an adhesive for the base...
Good luck!
Josh
KYdiyer is offline   Reply With Quote
Old 12-10-2017, 10:10 PM   #4
retired framer
Rewards Points: 18,434
You will want to level the floor for tile, why not do that before you set the base.
seat on acrylic shower pan wwsteeel Kitchen & Bath Remodeling 1 07-23-2015 02:18 PM
Instaling shower base and drain kc_fella Plumbing 38 03-07-2015 01:37 PM
How to remove a concrete shower pan g rag Kitchen & Bath Remodeling 3 11-06-2014 08:54 AM
Fiberglass Shower Base Install Q's yohan Plumbing 8 01-07-2011 03:46 PM
Installing acrylic shower base onto concrete floor Dawna106 Flooring 0 10-15-2010 05:42 PM
