Is Leaving 1/4" Between Bath Flange And CBU Necessary? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-21-2019, 07:30 PM   #1
Rewards Points: 100
Is leaving 1/4" between bath flange and CBU necessary?
Hey there. first time doing a bathroom remodel.
i hung the CBU so that the bottom of it rests on top of the flange. i realized after this is maybe not the best method since I've seen most CBU jobs leaving the gap for what i presume to be space to leave a strip of silicone. my CBU butts up very tight right on top of the flange.
my plan was to use a strip of tape over the gap and Redguard the whole strip similar to this. https://www.diytileguy.com/tile-tub-flange-gap/
tile would then hang down securely to the tub.
question is this an adequate waterproof method or do i need to cut the 1/4" gap.
thanks!
godblsmnymkr is offline   Reply With Quote
Old 04-22-2019, 05:41 AM   #2
Naildriver
chandler48's Avatar
Rewards Points: 916
Re: Is leaving 1/4" between bath flange and CBU necessary?
Ideally you would have installed a 6 mil vapor barrier behind the cbu and allowed it to extend into the tub slightly. You would, then, install the cbu on the walls allowing it to sit directly on the tub/shower flange, then cut the VB about 3/4" below that flange top. Your tile will cover it and any moisture that comes down the VB will exit into the tub/shower. I prefer to have a tight, but not caulked joint at the tub/shower to allow moisture to exit into the area, but others like caulked joints, so it is a toss up. I don't think you will experience any problem doing it without all the RedGard, etc. There won't be any wicking with your tile overhanging the cbu like you describe.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 04-22-2019, 05:21 PM   #3
Rewards Points: 100
tyvm for the reply. unfortunately, i only have a VB across the wall behind the bath and not on to the bath flange as well which is why i wanted to go the tape and redguard the flange connection with the CBU. what do you think?
