Large Wall Tile Installation - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-13-2018, 10:08 PM   #1
Rewards Points: 2
Large wall tile installation
Hello,
I am using 12x24 porcelain tile on my new shower enclosure and I'm not sure what type of mastic/mortar is to be used. The tiles weigh approx 7 lbs. Putting it up on top of Durock 1/2". Also how large of notch should i use?
Thank you!
dabulls1 is offline   Reply With Quote
Old 04-14-2018, 08:34 PM   #2
retired framer
Rewards Points: 18,610
Re: Large wall tile installation
Just bumping in the hopes a pro can see this thread.
Nealtw is offline   Reply With Quote
Old 04-15-2018, 05:54 AM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,624
Use LFT Thinset. Large Format Tile. Different strokes, but 1/4 x 1/4 trowel on the wall and back butter the tile as well. Don't use mastic in a wet area. It is best to attach a ledger around the perimeter, one tile size up from the finished floor to rest your courses of tile on. Once the wall is finished upward, then you can remove the ledger and finish below.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 04-15-2018, 06:42 AM   #4
Rewards Points: 52
Not a pro - but can you describe the water proofing method you are using?
tribe_fan is offline   Reply With Quote
Tags
bathroom remodel , tile installation
large bulge in wall - cause? diy'er on LI Drywall & Plaster 44 07-27-2019 12:45 AM
1" gap tile to wall, ok? groove65 Tiling, ceramics, marble 13 08-14-2015 12:32 AM
Retaining Wall Weeping Tile Problem cg3459 Landscaping & Lawn Care 3 06-16-2010 06:22 PM
Vertical tile on wall poolecw Flooring 2 06-01-2010 10:05 AM
Where do I make my tile cuts for the wall? petsparkle Kitchen & Bath Remodeling 6 04-25-2009 10:00 AM
