Laminate Over Tile Countertops? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 05-23-2018, 11:51 PM   #1
Rewards Points: 16
Laminate over tile countertops?
Half my kitchen has tile. Can I build up the grout lines with bondo, apply contact cement and laminate on top?
And the other side has laminate already, can I put laminate over laminate?
Sent from my SM-G928P using Tapatalk
iamomeed is offline   Reply With Quote
Old 05-24-2018, 06:21 AM   #2
Rewards Points: 7,182
Re: Laminate over tile countertops?
I have put laminate over laminate. Works fine. I did however, scuff up the surface with sandpaper to ensure good adhesive bond.
I think putting laminate over tile will have a very high possibility of lines telegraphing through. Not just the grout lines, but all the tiles also have to be on exactly the same plane.
SPS-1 is online now   Reply With Quote
Old 05-24-2018, 07:52 AM   #3
Rewards Points: 16
Ok should I remove the tile first and make sure the counter is smooth?
Old 05-24-2018, 08:12 AM   #4
That would be the safest route. Getting the sub-surface smooth does not sound like an easy task -- maybe put a piece of plywood over the tile sub-surface.
The way I know that you can laminate over laminate is one time I put down laminate over a cabinet door. I tried too hard to re-use one brush when putting down the contact cement and must have left a little lump of old dried glue on the sub-surface --- it telegraphed right through the laminate. Gluing surface must be very smooth and flat.
PS - don't use a brush -- buy those throw-away foam rollers for the contact cement.
The Following User Says Thank You to SPS-1 For This Useful Post:
iamomeed (05-24-2018)
Wood floor over laminate tile Bgmac Flooring 5 05-08-2016 08:37 PM
Asbestos Removal, Porcelain Tile Installation jimbriam Flooring 15 01-30-2012 01:46 PM
Ceramic Tile or Laminate Wood Flooring PearlWhiteGT Flooring 5 01-10-2012 01:56 PM
asbestos tile under laminate? bubbler Flooring 1 12-05-2010 01:53 PM
Transition laminate to higher fireplace tile Slippin Flooring 1 03-17-2009 08:22 PM
