Laminate Countertops - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 06-26-2012, 09:00 AM   #1
Rewards Points: 51
laminate countertops
Ok we are going to put a cheap laminate countertop in our kitchen. My issue is the top needs to be 12 ft long all lowes carrys instock are 10 ft.
Can you put 2 of these together on a straight edge or only on the 45 edge?
joelowrider is offline   Reply With Quote
Old 06-26-2012, 01:56 PM   #2
Maybe put the seam near the sink or cooktop? The visibility of the seam will depend on the quality of your cuts, the type of laminate, even any pattern and the color.
Post a few pics of the area and the proposed counter.
Evstarr is offline   Reply With Quote
Old 06-26-2012, 05:08 PM   #3
Rewards Points: 512
you can totally attach 2 laminate countertops together. but if you need 12' i'd shop around and find one that is 12' so theres no joint
princelake is offline   Reply With Quote
Old 06-26-2012, 07:58 PM   #4
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,136
Find a local "top shop" and have a proper plywood countertop made...
with laminate glued to it. You can still do the install.
The extra $100 or so will be money well spent.
Old 06-29-2012, 10:17 AM   #5
Coconut Pete's paella!
CoconutPete's Avatar
Rewards Points: 504
I ripped a 12' one out of my kitchen in February. They definitely exist.
CoconutPete is offline   Reply With Quote
Old 06-29-2012, 03:25 PM   #6
The answer to your question is YES, you can bolt 2 straight pieces of laminate post form countertops together as long as you purchase a "left" and "right" section so the bolt routes are in the correct place.
I would suggest adding clear kitchen and bath silicone in the joint before bolting together, this will keep water from ruining the particle board the laminate is glued to. Good luck
FYI for DIYers
a 12 ft top can be ordered with no seams.
3rdGeneration is offline   Reply With Quote
The Following User Says Thank You to 3rdGeneration For This Useful Post:
Evstarr (07-07-2012)
Laminate Countertops cibula11 General DIY Discussions 6 08-31-2011 04:05 PM
installing laminate countertops & repainting cabinets shocanfixit Carpentry 7 03-31-2011 11:52 PM
Mitre or butt joint for laminate countertops with roundover edge? tigereye Kitchen & Bath Remodeling 1 02-04-2010 10:33 AM
Need advice/tips on tearing out old laminate countertops TumsGum Kitchen & Bath Remodeling 6 03-07-2009 09:52 AM
Wilsonart post-form laminate countertops?? J187 Remodeling 7 05-04-2007 02:16 PM
