Kitchen Sink Removal - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-18-2016, 02:15 AM   #1
I would like to replace my undermount cast iron sink with a drop in stainless steel sink. I've looked under the sink and there are no clips, it should be hanging over the cabinet edge and sandwiched with the granite on top. There doesn't seem to be any easy way to remove the sink as I would have to remove the whole countertop slab and then lift it out.
Cast iron bathtubs can be destroyed, my question is, could I do the same safely to my sink? I think I can just destroy the whole sink and drop in my new sink afterwards. If I were to destroy it, would the blunt force possibly damage the countertop as well? That is what I am most afraid of.
Any ideas or suggestions to tackle this sink? Thanks.
bloopy87 is offline   Reply With Quote
Old 04-18-2016, 04:54 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 604
Re: Kitchen Sink Removal
Cast iron sinks are often held in place by sheer weight and a bead of caulk. Run a putty knife between the sink and the granite to cut the caulk. The sink should lift out.
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 04-18-2016, 06:47 AM   #3
Rewards Points: 18
If that picture is your current sink, it is not an undermount sink, it is a top mount sink. The rolled edge sits on the countertop and is likely csulked in. As the previous oost stated run a putty knife between the rolled edge and the countertop and you should be able to lift it out but it will be heavy. If the caulk is dry and hard try heating it with a blow dryer or heat gun to soften it. Also that countertop looks more like Corian than granite. If so, use the blow dryer rather than the heat gun since I believe Corian will melt.
Sent from my LG-D415 using Tapatalk
jeffmattero76 is offline   Reply With Quote
Old 04-18-2016, 07:15 AM   #4
Property Mgt/Maint
Rewards Points: 6,368
Better make sure a new SS sink will fit, before you destroy this one.
The opening is usually cut to match a specific sink. Looks like your sink is
dropped into a recess, which will make cutting the caulk under the flange difficult or
impossible.
Yodaman is offline   Reply With Quote
Old 04-18-2016, 02:04 PM   #5
RickMacKay's Avatar
Rewards Points: 114
It won't be easy. You might try a diamond blade on a worm drive saw. Have a helper spray water to keep the blade wet, and literally cut out most of the sink. I would block it up with 2x4's also so pieces don't crash into the base cabinet or fall and push up into the top. If the sink lip is sandwiched between the bottom of the counter and the top of the cabinets, a grinder with a diamond blade might be in order to get out strips of sink and caulk. A multi tool also has a thin blade and can get into that space. Good luck!
RickMacKay is offline   Reply With Quote
Old 04-18-2016, 08:22 PM   #6
Retired Moderator
Rewards Points: 7,174
Post a picture from the underside of the sink,please.
Often the cast iron sink is resting on some wood framing that was installed before the sink and counter top were installed.
If that is the case--that framing will need to be cut out----with the sink supported so it does not drop when the framing is cut out.
Old 04-19-2016, 12:58 AM   #7
I have removed a small portion of the caulking, a portion of the lip is still underneath the granite. Measurement of the sink is 31x20". Even if I remove all the caulking, I do not think I can just lift it out.
Also attached underneath of the sink, there are support framing around the edges.
Old 04-19-2016, 06:35 AM   #8
Retired Moderator
You will need to remove that from inside the cabinet.
first, lay a 2x4 across the counter above the sink---then loop a rope through the drain holes and tie the sink to the 2x4---
You may need to remove some of the plumbing inside the cabinet so the sink will not crush the pipes as you lower it--
You have bitten off a tough,two man job there---Mike--
Old 04-19-2016, 06:42 AM   #9
Rewards Points: 18
The new pictures make me change my mind on this. From the new pictures it sppears that this is a top mount sink that was mounted as an undermount sink.
If the added wooden supports under the sink were removed would the sink be supported by anything else? It appears to me that the wood is what is holding the sink in place and the caulk is simply sealing the edge so water cant get through. If that is the case, i would build something to "catch" the sink after you remove the existing wooden supports. Perhaps a 2x4 across the opening from the top with rope or wire going through the drain holes and tied to the 2x4 so that when you remove the existing wooden supports the sink will not crash down inside the cabinet.
Hope that helps!
The Following User Says Thank You to jeffmattero76 For This Useful Post:
oh'mike (04-23-2016)
Need Help With Adding Sink Next To Washer, Which Overflows Kitchen Sink JustinRampage Plumbing 36 01-30-2016 10:26 AM
Kitchen Sink Faucet Removal issue msteele Plumbing 2 07-07-2013 04:04 PM
Resetting Undermount Kitchen Sink Voss Plumbing 0 02-24-2012 12:47 PM
Anybody install or own a CORNER kitchen sink? Also RTA cabs... matermark Kitchen & Bath Remodeling 2 01-24-2009 05:41 PM
Rehabbing a porcelain kitchen sink guenthecat Remodeling 10 12-18-2007 10:10 AM
