Kitchen Duct Dilemma - Going Against The Grain - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-21-2019, 08:24 PM   #1
Rewards Points: 298
Kitchen Duct Dilemma - Going against the grain
Remote Blower, Straight and smooth, etc, etc. Ideal run for any ductwork I suppose.
Sorta in a weird pickle for this new build. 1200CFM blower and the duct run is a bit against -best practice-. I did a test fit and the noise is acceptable.....but not ideal. I'm working on constraints of the layout
So basically
Hood Blower
Right off the hood blower is a 10" 90 Degree Elbow to make it go right
Then two 45"s to make a turn vertical
Then up to the roof
Yeah, I know I should have like 2 feet from the blower off that's 1st elbow. It is what is is. The noise levels is ~acceptable~.
Only issue aside from the run itself is some direct backpressure coming off the 90. It is what it is though...
I'm sure the air will be moving, albit not ideal. The oil particulates that the filters don't catch might be a ~sticking point~ though right ?
mobiledynamics is offline   Reply With Quote
Old 01-22-2019, 07:12 PM   #2
Rewards Points: 1,272
Re: Kitchen Duct Dilemma - Going against the grain
Tear out whatever is causing the immediate right turn and do it up right
Make it right Mike
195795 is offline   Reply With Quote
Old 01-24-2019, 01:26 AM   #3
Rewards Points: 484
Whenever I need to turn on the exhaust fan I would also be opening the windows as well. So with my last kitchen remodel I put a microwave oven with fan over the cook top but did not hook it up. No code requirement for an exhaust fan in a kitchen even with a gas cooktop.
Calson is offline   Reply With Quote
Old 01-24-2019, 09:57 AM   #4
Unless local code adoption applies
Supply Duct sizing Master Brian HVAC 24 05-07-2016 08:48 AM
HRV Duct Sizing? toddmanqa HVAC 6 01-11-2013 02:43 AM
Kitchen Exhaust Hood 7" Duct Hookup smata67 HVAC 2 04-05-2012 09:07 AM
Planning on New duct work..any feedback... kilosos2 HVAC 28 01-26-2011 09:21 AM
Kitchen dilemma gnosti83 Kitchen & Bath Remodeling 5 04-26-2010 09:38 PM
