Kitchen Cabinets On Top Of Finish Floor? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 10-26-2011, 12:26 PM   #1
Kitchen Cabinets on top of finish floor?
In a kitchen remodel, should the Cabinets go on top of the finish floor? (vinyl or tile) I've heard different opinions from local contractors/craftsmen on this point.
Thanks,
ken24 is offline   Reply With Quote
Old 10-26-2011, 10:43 PM   #2
Military Mom of 4
Snav's Avatar
In my view it depends on the flooring or your budget - it doesn't really matter. You should decide based on what is more important to you.
If it's expensive: not flooring under your cabinets can save you possibly hundreds of dollars.
If it's thin and cheap like laminate: easier to roll it out to the corners as cabinets set in place just inhibit the use of it.
If it's fragile or easily scratched or messed up: lay the flooring after - any installation of anything can damage it and cause problems which can cost money sometimes. . . nothing sucks more than that!
So - cost, ease of install, preserving the quality. What you do relies on what's more important to you.
I - personally - am doing cheap thin vinyl flooring tiles - to save money (though not much) I won't be putting it under the cabinets and this will also spare me the annoyance of any potential damages - which can be fixed - but not without getting under my skin first.
The only problem that comes from not flooring under counters is water-damage . . . this area should be water-proofed like a bathroom (above code - nontraditional - but an unprotected floor is potential water damage and bucco bucks later on.)
If you're installing a thick flooring (like hardwood or tile) it's common to fill the area under the cabinets with a cheap flooring material (osb, ply, etc) that's the same thickness so you save cost - but the real flooring isn't overlapping too much of the cabinetry which makes it easier to remodel the kitchen at some point.
At this present moment in time I am making cabinets for the kitchen - just in case you wanted to know what I'm doing when I'm not around.
Snav is offline   Reply With Quote
The Following 2 Users Say Thank You to Snav For This Useful Post:
ken24 (10-27-2011), yurtgirl (06-03-2012)
Old 10-29-2011, 07:00 PM   #3
Rewards Points: 5,348
I always put the whole floor down before the cabinets go in.
Ron
B. Franklin 1759
Old 10-29-2011, 07:47 PM   #4
Rewards Points: 582
yes I agree with you ron we also put floor down before cabinets..ben
Leveling Kitchen Cabinets for Granite - how level?? vsheetz Kitchen & Bath Remodeling 13 03-02-2012 07:54 PM
Removing textured finish from kitchen cabinets jbwaechter Remodeling 6 10-04-2010 01:12 PM
KraftMaid cabinets BlueBSH Building & Construction 8 09-27-2010 08:51 PM
Cabinets or floor first? davecuz Flooring 5 08-06-2010 09:07 AM
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
