Kitchen Cabinets.....Which Ones? - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 07-29-2017, 08:52 PM   #16
Rewards Points: 12
Re: Kitchen cabinets.....Which ones?
I've had good luck with Cabinets ToGo but they are YMMV because of being independent at each location. The quality of the cabinets are great, the service varies from location to location. I plan to buy them with my remodel that I'm about to post on right now.
shiba_missy is offline   Reply With Quote
Old 07-29-2017, 08:56 PM   #17
Naildriver
chandler48's Avatar
Rewards Points: 3,546
French Guy, No where on their site do they give information as to the construction quality or materials used in building them, so I can't comment on their quality. "Ready to Assemble" tells me they are presswood carcasses with cam locks to put them together.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is online now   Reply With Quote
Old 07-30-2017, 06:37 AM   #18
Rewards Points: 898
Looks good. RTA is to save on shipping from China. You can pack a lot of flat-pack cabinets in a shipping crate when the cabinets aren't full of that fresh sweet pure Beijing O2
Face Frames are " x 1" Solid hardwood
Tops and bottom panels are " thick multi-ply hardwood plywood
Base bottom panels are ⅜" thick.
Toe kicks are " thick hardwood plywood
End panels are " thick multi-ply hardwood plywood.
Adjustable shelves exceed industry standards with ⅝" thick multi-ply hardwood Plywood & edge banded with wood tape.
6mm bore fluted metal shelf clips are adjustable on 2" increments.
Back panels are " thick multi-ply hardwood plywood -
" high density fiber doors.
Full Overlay Doors and Drawer Fronts
Concealed Hinges with 6-way adjustable, soft-closing dampers.
⅝" drawer front, back and 2 sides with plywood drawer bottoms. Dovetail construction.
Soft-Closing, Full Extension Drawer Glides.
BIG Johnson is offline   Reply With Quote
Old 07-30-2017, 06:42 AM   #19
Rewards Points: 898
Here's a budget kitchen I did a while back with them:
Old 07-30-2017, 06:44 AM   #20
Rewards Points: 898
Pic. 2:
Old 07-30-2017, 06:46 AM   #21
Rewards Points: 898
Pic. 3:
Old 07-30-2017, 06:59 AM   #22
Naildriver
chandler48's Avatar
That is good information to know. I am impressed.
Larry......
Old 07-30-2017, 07:30 AM   #23
Rewards Points: 1,172
Based on the pictures, was it the "Tuscany" model from RTACabinetstore?
https://www.rtacabinetstore.com/RTA-...chen-cabinets/
When you did the installation, how did you find the assembly process, and the overall quality?
french_guy is offline   Reply With Quote
Old 07-30-2017, 07:40 AM   #24
Rewards Points: 898
I haven't bought from those 2 stores, the ones I buy come with color matched interiors. The 2 listed above only come CM if you get glass doors. I like that even the shelves are painted plywood as well as the lazy Susan's. A lot (even higher end) of LS's have plastic shelves with a metal tube going up the middle.
Don't get me wrong. These cabs. do have their issues but they work for me. You're not going to get away using them on a $50K remodel.
Old 07-30-2017, 07:45 AM   #25
Rewards Points: 898
Assembly is easy. I glue and nail and use the included hardware. Buy scribe moulding for everything to cover up the brad nails if you are going to glue and nail. I also glue the dovetails on the drawer boxes.
I always have to get repacement pcs because they come damaged. Be ready for this to add significant time to your project. I had the face of my lazy S come scratched up so I had to put off granite templating until the new face came.
I'd avoid the big pantry cabinets.
They look close. The ones I installed were a solid cream color. Not glazed to look aged. I've also done the white shaker and a dark maple.
https://www.stockcabinetexpress.com/...FVg6gQodDZkPpQ
Whatever you decide, make sure to order the sample door first.
Old 07-30-2017, 08:23 AM   #26
A "Handy Husband"
rjniles's Avatar
Rewards Points: 584
I have remodeled 2 kitchens, first using cabinets that I had to assemble, second using assembled cabinets. Assembling cabinets is a time consuming PIA. if I ever do another kitchen it will be with assembled units.
Sent from my RCT6203W46 using Tapatalk
My electrical answers are based on 2014 NEC, you may have local amendments.
Old 07-30-2017, 09:29 AM   #27
Naildriver
chandler48's Avatar
I like the convenience of assembled cabinets, but if they are shipped in from a long distance, be prepared for massive damage as they are not packaged very well. I know the RTA units are time consuming, but at least their packaging is tight. Toss up.
Larry......
Old 08-01-2017, 06:06 PM   #28
The model I'm looking for at RTAcabinetstore uses the plastic cam-lock system...
Not sure it's good ???
Best paint for kitchen cabinets? W1ldC4ts14 Painting 10 10-13-2014 01:53 PM
Antiquing kitchen cabinets Beeba Painting 1 09-17-2012 07:22 PM
ceiling/wall slanting over kitchen cabinets fdf Remodeling 8 02-26-2012 02:52 PM
Are Kitchen Cabinets Secure richard7994 General DIY Discussions 6 11-06-2011 06:21 PM
Upper Kitchen Cabinets latemoy Carpentry 3 09-13-2011 06:31 AM
