Kitchen Cabinet Help - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 04-09-2014, 02:22 PM   #1
Question
Kitchen cabinet help
I am installing new kitchen cabinets and my wife wanted a corner cabinet installed right next to the under cabinet microwave. The issue now is that the door to the cabinet will only open 45 degrees. Does anyone know of a hinge that would extend out from the frame about 4 inches and then swing 135 degrees so we can have full access to the cabinet? Has anyone had success attaching a cabinet hinge to a drawer slide to allow for this?
Attached is a pdf of the kitchen layout... Thanks
Mike
mooses280zx is offline   Reply With Quote
Old 04-09-2014, 09:56 PM   #2
Rewards Points: 996
what is see is a poor design. with the little info i have. what i would do = get a narrower door. hinge it on the other side. and fill the gap.
Fix'n it is offline   Reply With Quote
Old 04-14-2014, 08:44 PM   #3
Rewards Points: 256
can you pull the corner cabinet out 3 inches then get a narrower one on the left , say 12 instead of 15 , 15 instead of 18 , whatever in on the left side .
oldrivers is offline   Reply With Quote
Old 04-14-2014, 08:47 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Put the hinges on the top of the cabinet so you can lift the door towards the ceiling.
sublime2 is offline   Reply With Quote
Old 04-14-2014, 09:09 PM   #5
Rewards Points: 17,890
A whole lot simpler to add a 3 or 4" spacer between the corner cabinet and the one to it's right.
Old 04-14-2014, 09:43 PM   #6
Rewards Points: 996
no doubt. but i am figuring that there isn't any room.
Old 04-18-2014, 06:20 AM   #7
No, Fix'n it is correct, there is no room for a filler strip. The original layout of the kitchen had a flat cabinet in that corner. My wife wanted to use a corner cabinet to use the space more efficiently. It was my dumb idea to suggest the under cabinet microwave. But I would be having the same problem if I went with a vent hood as well.
Thanks for the input.
Old 04-18-2014, 12:42 PM   #8
MT Stringer's Avatar
Rewards Points: 254
I am interested in seeing how you figure this one out. I would be willing to bet you are not the only one that has "painted yourself into a corner". :-)
It does look like adding a filler strip to the right side and replacing the door with one that is narrower would be one possible solution.
Good luck.
Mike
MT Stringer is offline   Reply With Quote
Old 04-18-2014, 08:39 PM   #9
Rewards Points: 454
Dam women
scottktmrider is offline   Reply With Quote
Old 04-19-2014, 08:59 AM   #10
Rewards Points: 996
moose. lets see some real pics of what you are dealing with. and make them jpg's.
somehow or another, i am sure there is an acceptable solution.
Old 04-22-2014, 12:42 AM   #11
Approved Remodeling help me to decide and to design my kitchen.
jasper121 is offline   Reply With Quote
Access through kitchen cabinet to pipes taylorroad Carpentry 4 09-01-2012 06:09 AM
Kitchen cabinet conundrum allbymyself Kitchen & Bath Remodeling 18 01-24-2011 11:11 PM
outlet in kitchen cabinet timchi29 Electrical 2 01-03-2011 08:25 PM
kitchen cabinet mircrowave range marin001 Building & Construction 1 12-10-2010 05:32 PM
Kitchen sink not centered. gmhut Plumbing 5 06-01-2010 11:44 AM
