Kitchen Cabinet Face Lift. - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By mark sr
Old 12-03-2017, 08:13 PM   #1
Rewards Points: 2
Kitchen cabinet face lift.
Looking to updo the kitchen. Itd in need of a major overhual but not gonna happen.
Thinking maybe I could give my cabinets a face lift.
Thoughts on how i might redo my doors. These cabinets are pretty simple 60s style.
Wanna white wash pallets for the back splash.
Thinking aboit finding a big oak tree and doing a slab for the counter top.
Gotta redo thr floor is only 2 years old but it is gross.
So thoughts on what I could do with the doors?
Sent from my SAMSUNG-SM-G891A using Tapatalk
Kitchen cabinet face lift.-1.jpg   Kitchen cabinet face lift.-2.jpg   Kitchen cabinet face lift.-3.jpg
tg.weaver is offline   Reply With Quote
Old 12-03-2017, 08:16 PM   #2
Rewards Points: 2
Re: Kitchen cabinet face lift.
I kinda was wondering if i could make some shaker style doors and put them on
Old 12-03-2017, 08:58 PM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 9,252
Your face frames look to be in decent shape.
My personal opinion....replace all the doors. It will totally change the way your kitchen looks. There is just not much you can do with those existing doors.
I'm doing that to my kitchen now.....it's not going to be cheap....but, the place I get them from does outstanding work.
All told, I'm getting 25 doors and 19 drawer faces...solid soft maple. It's going to cost me about $2k. But....the kitchen will look like it had a $10K face lift.
But I am spending $10K on Quartz counter tops.
I redid the floor....new tile...$500 total. I make my one cabinet frames...so I have about another $500 in plywood and soft maple.
When I'm all done I'll have about $14K into the project....but farming it out would have cost about $35K+. And I'll never have to touch it again.
Oh....forgot to add.....I added a second sink (prep)...and replaced the main one....both are solid copper.....and we are really loving them. So easy to keep clean. The main one is a farm house sink...huge....
We didn't realize how nice it would be having 2 sinks.
I am adding this link just for reference....They are too far from you...but, it will give you an idea of your options.
http://www.dreesinc.com/
Also, look into Blum hinges. You really want to get away from those old style external hinges....
Old 12-04-2017, 05:07 AM   #4
retired painter
Rewards Points: 1,362
I agree replacing the doors would be the most cost effective method to change the look. Paint the face of the cabinets with an enamel color that compliments the new look.
While oak [or any wood] looks sharp as a countertop it isn't a good idea. Too easy for water to soak between the boards or into cracks and discolor the wood.
mark sr is online now   Reply With Quote
Old 12-04-2017, 06:12 AM   #5
Rewards Points: 2
I was gonna mill it myself one slab no cracks and ise a bar style epoxy to seal it
Old 12-04-2017, 06:13 AM   #6
retired painter
Wood is prone to crack/split as it dries out along with temp/humidity changes.
Mike Milam likes this.
Old 12-04-2017, 09:31 AM   #7
I just put share style trim on my slab style kitchen doors, it was dead-easy with a cheap nail gun and used compressor.
Toml is offline   Reply With Quote
Old 12-04-2017, 02:04 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 1,486
There is something you can do if you have the tools and know how. You can cut the area out were a raised panel would go, leaving 2 inches or what ever you want the width of the rail and stile to be.
You could cut a small bead that would stand proud of the door to cover the raw plywood edge where you cut out for the raised panel. You could also cut the rabbit off the outside edge of the doors and replace with a larger bead like in the photo below of the trim in our bedroom.
If you don't want raised panels, you could do a recessed panel. Just a suggestion to save some bucks and look good.
New members: Please consider adding your location to your profile.
Lawyers believe a man is innocent until proven broke.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 12-06-2017, 06:23 AM   #9
Rewards Points: 2
Thanks could u show some more pics
Old 12-06-2017, 10:54 AM   #10
Ole Wood Worker
BigJim's Avatar
What do you want pictures of?
Jim
Old 12-06-2017, 10:59 AM   #11
Rewards Points: 2
Oh othe sides of the canite
Old 12-06-2017, 12:10 PM   #12
Ole Wood Worker
BigJim's Avatar
The picture above is of the trim on our window, this same design could be applied to your situation using the doors you have now, to cover up the raw edges of the plywood after you cut and trim them.
I will have to look back and find some cabinets I have built using this design. When I find one I will post some pictures of them.
Jim
Running new kitchen drain because 1953 wasn't friendly with connection height scgt1 Plumbing 16 02-03-2017 11:57 AM
Kitchen cabinet knobs - finish, please help crankbait09 Kitchen & Bath Remodeling 12 01-04-2017 09:50 PM
Kitchen Cabinet Install. Help with Square hboogz Carpentry 5 05-12-2015 08:22 AM
Finally mounted upper kitchen cabinet to sloped wall! stripedbass Carpentry 7 01-30-2015 01:23 PM
Looking for suggestions on kitchen cabinet stain color.....pictures attached Rhizzlebop Interior Decorating 15 04-05-2010 02:43 PM
