Kitchen Backsplash: Install Tile First, Or Attach Shelf? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By oh'mike
Old 07-27-2016, 10:02 PM   #1
ZZZZZ's Avatar
Rewards Points: 2,136
Kitchen backsplash: install tile first, or attach shelf?
I'm getting ready to install some 1" glass & metal mosaic tiles in a 13" mesh as a kitchen backsplash. I also want to install a small spice rack shelf that will sit behind the stove top (and below the range hood).
The shelf is 26" wide, slightly less wide than the stove, and it is designed so that it has tabs that stick down behind and below the stove top, and it will attach with a few screws into the studs down there, out of view..
Would you install the shelf first and cut and install the tile to fit around the outside of the shelf, or first tile behind the shelf and just cut out the four tiles that would be in the way of the mounting screws?
I guess what I'm asking is should there actually be tile behind the shelf, or just around its perimeter, if you know what I mean, Vern.
Or it's no big deal either way?
ZZZZZ is online now   Reply With Quote
Old 07-28-2016, 06:02 AM   #2
Retired Moderator
Rewards Points: 7,174
Re: Kitchen backsplash: install tile first, or attach shelf?
Tile first-----the mosaic is tough to cut around anything---a shelf is considered an optional accessory which might get changed before the tile work.
ZZZZZ likes this.
Old 07-28-2016, 10:46 AM   #3
Rewards Points: 2,432
Think about where the screw holes will be for hanging the rack. Glass would not be easy to drill through. You probably will have to use the grout joints. That means you may not find the studs.
carpdad is offline   Reply With Quote
Backsplash question in kitchen (glass tile) bluelakeside Kitchen & Bath Remodeling 3 11-03-2014 09:57 AM
Tool for cutting tile when laying kitchen backsplash? maj0819 Kitchen & Bath Remodeling 3 07-15-2014 12:08 PM
Kitchen range install and backerboard on tile floor joemc3 Flooring 4 07-17-2013 06:43 AM
Bathroom tile installation demolition Kitchen & Bath Remodeling 4 04-10-2011 07:48 PM
Kitchen tile backsplash trim Janer Remodeling 2 01-18-2011 09:33 AM
