Kerdi System Questions - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 11-08-2017, 07:25 AM   #1
Rewards Points: 252
I have a few questions before I embark on a shower install with Kerdi:
Is there a way to build a custom shower niche that will be properly waterproofed, or do you need to stick with the preformed niches that Kerdi sells?
If you create a custom shower bench, do you need to use the preformed corners around it, or can you use Kerdi Band around the corners?
Thanks.
1995droptopz is offline   Reply With Quote
Old 11-08-2017, 07:39 AM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,260
Re: Kerdi System Questions
There no reason you have stay with the cookie cutter sizes. All of the systems can be adapted to work with whatever you ultimate vision of the shower is.
Old 11-08-2017, 08:38 AM   #3
Rewards Points: 252
What would be the proper way to build the niche then? I have found some ways of doing it with the Kerdi board, but I cannot get a smaller quantity than 12 boards shipped, and do not know of any local distributors.
Old 11-08-2017, 09:15 AM   #4
Rewards Points: 252
Also, I am planning a 48x60 shower. Based on the dimensions I will end up with a seam on the floor in the Kerdi. From what I can gather reading the installation instructions, this is acceptable as long as there is a 2" overlap or you butt the sheets together and install kerdi Band with thinset. Is this correct? I am extremely nervous about leaks since every shower pan I have encountered has leaked at some point. I have never done one up to this point for that reason.
Old 11-10-2017, 07:02 PM   #5
firehawkmph's Avatar
Rewards Points: 2,452
You are correct on the 2" overlap when seaming Kerdi. Band would be ok too, but the overlapping is easier. The Schluter system is a good product as long as you follow their installation instructions. I have used other premodern niches with Kerdi and had no issues.
Mike Hawkins
firehawkmph is offline   Reply With Quote
RO System questions roughneck Plumbing 7 03-05-2015 02:23 PM
Hrv system, basic questions mj12 HVAC 4 01-13-2015 03:08 PM
Small 2 Bedroom, 900 sq. ft. Home HVAC System Questions markcr HVAC 7 04-18-2011 07:05 PM
Drip System Questions Justin Case Landscaping & Lawn Care 1 10-22-2007 11:16 PM
