KERDI Shower Systems - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
Old 09-23-2017, 07:25 PM   #1
Rewards Points: 150
Has anyone had any involvement with these Schluter "KERDI Shower Systems"
I'm really interested in the KERDI shower base and curb system.
https://www.schluter.com/schluter-us...er-System/c/SS
Kemper100 is offline   Reply With Quote
Old 09-23-2017, 07:43 PM   #2
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 4,322
Re: KERDI Shower Systems
Well regarded and thought out system.
As long as you follow the steps, they work like a charm.
Only drawback is they aren't cheap.
chandler48 likes this.
Old 09-23-2017, 07:46 PM   #3
Naildriver
chandler48's Avatar
Rewards Points: 3,676
It can be a time saver (over packing in a pre-slope/liner/slope) but you do have to follow all physics in layering it so water moves toward the drain if there are any seams like in the corners where the base meets the walls.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
The Following User Says Thank You to chandler48 For This Useful Post:
Kemper100 (09-24-2017)
Old 09-24-2017, 04:42 AM   #4
Rewards Points: 150
Please explain, the pan (poly section) is pre-sloped to allow the water to flow toward the drain correct?
Old 09-24-2017, 06:26 AM   #5
Naildriver
chandler48's Avatar
I said Kerdi was a time saver. Packing in a preslope/liner/slope is time and material consuming. The Kerdi system is better, but more expensive.
Larry......
PappyO (09-24-2017)
Old 09-24-2017, 08:00 AM   #6
Rewards Points: 92
Oh yea ok.......probably better for a novice like myself.
Is the Kerdi system like double the cost / more expensive over and above than the shower base with concrete build?
PappyO is offline   Reply With Quote
Old 09-24-2017, 08:38 AM   #7
Naildriver
chandler48's Avatar
About $2/sf for the mat. The pans kits will run around $500. I install oddly shaped showers sometimes, so we stick with the sand mix pack base.
Larry......
Old 09-24-2017, 09:17 AM   #8
Rewards Points: 92
This shower is roughly 6' X 4 basic rectangle
Old 09-24-2017, 11:41 AM   #9
Rewards Points: 898
You can do an old school pan for about $100. Mud, PVC, lath, 2x4's and drain (not including grate).
BIG Johnson is offline   Reply With Quote
Old 09-24-2017, 11:51 AM   #10
Rewards Points: 92
I'm leaning that way, budget is limited
Old 09-24-2017, 04:26 PM   #11
Rewards Points: 898
Here are the directions.
http://floorelf.com/how-to-create-a-shower-floor-part-1
The Following User Says Thank You to BIG Johnson For This Useful Post:
PappyO (09-25-2017)
Old 09-24-2017, 04:32 PM   #12
Rewards Points: 898
My local tile shop does a hybrid. They build a sloped mud pan then use the kerdi drain and membrane. Said they've never had a leak. They have 3 or 4 tile crews doing showers every week.
Mud pan probably costs $25 with lath and roofing felt.
Kerdi drain is $100
kerdi membrane is $150 for 108 sq ft. ~ 20 sq ft. for the floor then the rest for the walls. They place kerdi membrane directly over regular drywall. Then kerdi band between wall and floor.
https://www.amazon.com/Schluter-Kerd.../dp/B003C6EQPE
I'm going this route on my next house. The kerdi drain comes with a grate which is $35 separate so it's really only about $60 more than the PVC route drain wise. $55 if you have to buy a bag of pea stone and a tube of silicone. $40 if you have to buy the special PVC liner cement and corners. See where this is going?
PappyO (09-25-2017)
Old 09-25-2017, 07:06 AM   #13
Rewards Points: 92
Kerdi drain is $100
So no need for fiber cement board?
Old 09-25-2017, 07:10 AM   #14
Rewards Points: 898
Not with kerdi membrane installed properly over drywall.
Old 09-25-2017, 11:33 AM   #15
Rewards Points: 92
Thanks!
Question what do you typically use for a moisture barrier?
kerdi shower kits mule98h Tiling, ceramics, marble 5 03-27-2014 08:12 PM
Complete bathroom redesign- need help with shower placement Liv Kitchen & Bath Remodeling 0 03-08-2012 12:00 PM
Moisture-proofing kerdi shower walls tdarlingt Kitchen & Bath Remodeling 2 05-15-2011 06:11 PM
Schluter Kerdi shower system...help! secutanudu Kitchen & Bath Remodeling 3 07-18-2010 06:49 PM
Kerdi shower pan Eck4Life Flooring 7 01-29-2009 02:57 PM
