Kerdi Shower System Over Slab - Kitchen & Bath Remodeling - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-07-2010, 10:26 AM   #16
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Why does the guy on that site recommend adding more sand to the premixed stuff?
Typically the recipe for deck mud for years and years was (and still is) 4:1 or 5:1, just depends on who you want to argue with. Back in the days of buying 90# Portland bags and having a truck load of sand delivered to a job site for the construction of "deck mud" floors this was practical and economical and the products were there on site when needed for a shower.
But, in the case of a "shower only" all of that isn't at all feasible. Where does the extra sand come from? In truth, the sand should be "sharp sand", but try to buy a little bag of sharp sand and see what happens. It isn't usually available. Blast sand is not the right product and play sand and all-purpose sand is much too coarse and sometimes full of rocks.
To answer your question: The added sand is to enhance ones ability to shave and sculpt the surface since the product is not "poured" but instead placed, packed and sculpted. Just so happens most bagged sandmix is only 3:1, no big deal.
I should also mention that you should use only water to mix the sandmix, NO ADDITIVES. Mixing the sandmix with enhancement additives IS NOT NECESSARY and will only serve to make the mix sticky and harder to manage. Once placed and shaved if there are still some imperfections one can scrub the surface with a wooden float to correct any errors, it is easy to do.
XXX
The Following User Says Thank You to Bud Cline For This Useful Post:
secutanudu (04-07-2010)
Old 04-07-2010, 10:29 AM   #17
Just call me Andrew
Rewards Points: 1,032
Great - i'll go with the premade sand mix and nothing else other than some water. I appreciate it.
Andrew
secutanudu is offline   Reply With Quote
Old 04-09-2010, 08:15 AM   #18
Just call me Andrew
Another quick question regarding the Kerdi installation. Would you guys recommend doing concrete backer board for the shower walls, or just using drywall? Thanks.
Andrew
Old 04-09-2010, 09:20 AM   #19
Rewards Points: 5,348
I would use the concrete board.
Ron
Old 04-09-2010, 08:05 PM   #20
Tileguy
Bud Cline's Avatar
Rewards Points: 558
NO DRYWALL, NO GREENBOARD.
Technically those products were outlawed by building codes a few years ago for use in showers.
Take a look at using Denshield. It would be much better than using regular cement board.
XXX
Old 04-09-2010, 08:07 PM   #21
Just call me Andrew
I went out and bought hardi-backer concrete board, gonna go with that for the whole shower. Thanks for the advice.
Andrew
Old 04-09-2010, 08:11 PM   #22
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Hardi is a good product.
Don't forget you need a moisture barrier behind the Hardi.
Denshield does not require a moisture barrier behind it.
XXX
Old 04-09-2010, 08:13 PM   #23
Just call me Andrew
But isn't the kerdi membrane a moisture and water barrier? If that's installed properly, even the front of the hardi should get no moisture, right? The shower is on all inside walls, if that makes a difference.
Andrew
Old 04-09-2010, 08:26 PM   #24
Tileguy
Bud Cline's Avatar
Rewards Points: 558
MY BAD!!! I was forgetting the KERDI.
My apologies...drywall IS allowed behind KERDI. I would never use it but Schluter thinks it's OK.
I read and get involved in too many threads on a daily basis and sometimes they all seem to run together. I was lost for a few minutes.
Your OK.
XXX
Old 04-09-2010, 08:35 PM   #25
Registered User
Rewards Points: 526
Congratulations Bud! You fulfilled it, if only for a short time period--- "Some days I aspire to becoming a missing person."
I always enjoy reading your answers, Keep them up.
Be safe, Gary
Old 04-10-2010, 12:32 PM   #26
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I am s-o-o-o-o confused!!!
XXX
Kerdi shower base Joe F Building & Construction 5 11-04-2009 11:57 AM
kerdi shower base paluch General DIY Discussions 4 09-23-2009 08:08 AM
Shower Pan and concrete slab plumbing LTempleton Kitchen & Bath Remodeling 2 08-08-2009 12:47 PM
I thought I put it back together properly: leaky shower valve (Matco-Norca) shuuy Plumbing 1 06-18-2009 10:44 AM
shower in basement slab philip96 Plumbing 2 06-15-2008 09:46 PM
