Kerdi Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-04-2018, 09:49 AM   #1
cia2a's Avatar
Rewards Points: 30
Kerdi Pan
I am using a Kerdi pan over a concrete slab. I know to use unmodified thinset to install the pan. I am using Hardiboard for the walls and tiling on those.
1. Do I also use the unmodified for the Kerdi membrane that comes with it.?
2. Do I need to use unmodified for the tile over the membrane.?
Thanks everyone.
cia2a is offline   Reply With Quote
Old 02-04-2018, 12:11 PM   #2
MarginallyQualified
TarheelTerp's Avatar
Rewards Points: 4,130
Re: Kerdi Pan
I'd love to see some pictures of this project as you go along.
TarheelTerp is online now   Reply With Quote
Old 02-04-2018, 08:00 PM   #3
Tileguy
JazMan's Avatar
Rewards Points: 748
Re: Kerdi Pan
cia2a,
Yes to both Qs. Be sure to use a premium quality unmod. mortar, do you know which specific mortar you'll use? Be sure to damp sponge the Hardie just before applying the thinset mortar.
Jaz
MARBLE from ITALY & GREECE -PERLATO-PERLATINO-BOTTICINO-THASSOS-SIVEC-VOLAKAS-CALACATTA- NAXOS-Slabs-Tiles-Custom containers shipped to you - [email protected]
Old 02-05-2018, 09:21 AM   #4
Rewards Points: 576
Re: Kerdi Pan
Thanks everyone.
You may want to consider the Kerdi board. We did my sons shower with Hardi only because I was not aware of the Kerdi Board before starting.
IF you continue with the Hardi board, know that it will drink water so when applying the kerdi to it, you will need to mist it (hardi) with water before applying Kerdi and mortar. By using the Kerdi board, there is less work, IMO.
There is another website where you can get a ton of info and help, PM if you want it.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 02-06-2018, 05:49 AM   #5
cia2a's Avatar
Rewards Points: 30
Re: Kerdi Pan
No I have not chosen a mortar yet, any recommendations?
Old 02-06-2018, 05:55 AM   #6
cia2a's Avatar
Rewards Points: 30
Re: Kerdi Pan
I did a shower in my other house and used hardi on the walls with no issues. Looking at budget is why I chose this as opposed to the entire Kerdi shower kit, $475 vs $94 for hardi
Old 02-06-2018, 07:15 AM   #7
Rewards Points: 576
Re: Kerdi Pan
Valid point but for me, while I had no issues getting it (kerdi) mounted on the hardi, I feel the already mounted kerdi board is the way to go for us on the next bath. Simpler to use and cut, less seams and faster.
Good luck!
The Following User Says Thank You to digitalplumber For This Useful Post:
cia2a (02-06-2018)
Modified vs. Unmodified Thin Set for Kerdi Shower Install scotthu Tiling, ceramics, marble 2 09-22-2013 08:53 PM
Installing Kerdi board in bathroom JP's Dad Drywall & Plaster 3 04-02-2013 10:05 AM
Oh, The Decisions for Shower, Hot Mop? Kerdi? ddawg16 Plumbing 5 12-17-2012 09:33 AM
Kerdi Basement Shower ldogg Flooring 7 09-13-2009 08:28 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
