Kerdi Membrane Over Plywood Or CMU Bench? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree1Likes
  • 1 Post By diyer75
Old 11-20-2017, 02:52 PM   #1
Rewards Points: 24
Kerdi Membrane over Plywood or CMU Bench?
Hi,
I built my shower bench for my massive shower yesterday.
My question now is, do I use plywood then put the kerdi membrane over that? Or do I do Hardibacker/Durorock and then put the kerdi membrane over that instead? Or do I do plywood then Hardibacker then kerdi membrane?
I have the membrane just for this and the skylight in the shower. I have the Kerdi panels for the walls.
Please let me know which is the correct way to do this as I can't find the answer on the schulter site or elsewhere online.
Thank you!
diyer75 is offline   Reply With Quote
Old 11-20-2017, 03:46 PM   #2
Rewards Points: 426
Re: Kerdi Membrane over Plywood or CMU Bench?
Did you run the waterproofing under that structure and did you put fasteners through that bottom plate, through the waterproofing?
KC_Jones is online now   Reply With Quote
Old 11-20-2017, 04:59 PM   #3
Rewards Points: 24
The pan liner was already run and I build the bench on top of it. The Kerdi will waterproof the bench anyway, including the sill plate so it doesn't even need to have the liner under it anyway. So even if there are holes in the liner there, they are in the liner where the sill plate will be protected and water tight from the kerdi and the kerdi band and the rest. I considered that when I was doing it.
But that's not my question, I need to know whether to use plywood or hardibacker on the bench. Either way it will be waterproofed by the kerdi.
Old 11-20-2017, 05:30 PM   #4
Naildriver
chandler48's Avatar
Rewards Points: 3,640
CMU is concrete block. I only see wood framing. Edit: Use plywood for structural integrity. CBU is not structural. Then add your Kerdi.
Larry......
Half of Communications is Listening, and You can't Listen with your Mouth.
chandler48 is offline   Reply With Quote
Old 11-20-2017, 06:13 PM   #5
Rewards Points: 24
That was exactly my question. So I'll do the plywood then the kerdi on top - which mean I won't need the concrete board/hardibacker at all.
Thanks!
chandler48 likes this.
No Membrane for Tile Subfloor shanefarr Kitchen & Bath Remodeling 7 07-18-2015 12:04 PM
Bathroom Remodel 2nd floor ckrohn83 Kitchen & Bath Remodeling 78 10-01-2014 11:26 AM
Installing Kerdi board in bathroom JP's Dad Drywall & Plaster 3 04-02-2013 10:05 AM
Prep Shower Walls / Shower Bench Question LeviDIY Remodeling 8 06-10-2011 05:09 AM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 10:42 AM
