Kerdi Board Transition To Acrylic Shower Pan - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-22-2012, 09:05 AM
Kerdi board transition to acrylic shower pan
I am unclear about the proper way to transition at the bottom of a kerdi board to an acrylic shower receptor. The pan has a surprising short flange. Would appreciate advice about alternatives. All I see on line are transitions to tiled shower pans.
Hollan is offline
Old 01-22-2012, 09:18 AM
Rewards Points: 17,890
In most cases I shim out the wall with lattis so the board will fit over the flange without having to bow out, the board gets installed within 3/8" of the pan, the tile goes to within 1/4, caulking fills in the gap.
joecaption is offline
Old 01-22-2012, 09:26 AM
Thanks for the response. What concerns me is the flange is very short. My understanding is that the flange directs water that has penetrated the tile/grout back into the pan but with a layer of sealant between tile and pan how can that work. Most pans have a higher flange. Mine is only about a quarter inch and my concern is it will just flow back into the wall.
Hollan is offline
Old 01-22-2012, 10:04 AM
Retired Moderator
Rewards Points: 7,174
That sounds like the wrong pan---flange is usually 3/4" or bigger--
Never used Kerdi Board--new product---I typically rest the backer on top of the flange--then fill the gap with thinset as I tile--
But 1/4" flange---that worries me--
oh'mike is offline
Old 01-22-2012, 10:15 AM
mike owes me $53 dollars
Tech Dawg's Avatar
I don't use kerdi board but wouldn't it make more sense to rabbet out the back of the board a little so it would fit straight down over the lip with out bowing and set it in a bead of Kerdi fix which would minimize a 3/8" gap down to 1/16" and then run a finish bead of Kerdi fix on the outside to completely seal it?
Todd
www.aloneeagle.com
Tech Dawg is offline
Old 01-22-2012, 12:51 PM
Interesting suggestion. Thanks.
Still worries me about whether this is the right way. Here is a link to the installation guide[/URL] for this very expensive shower pan:http://www.wetstyle.ca/sites/default...ouche-10_0.pdf
Hollan is offline
Assistance with tile layout / transition between cement board and drywall JeffreyMCooper Tiling, ceramics, marble 4 08-20-2011 11:47 AM
Moisture-proofing kerdi shower walls tdarlingt Kitchen & Bath Remodeling 2 05-15-2011 06:11 PM
Problem with shower pan and drain ohiogirl1965 Plumbing 1 06-07-2010 06:33 AM
Kerdi Basement Shower ldogg Flooring 7 09-13-2009 08:28 PM
Steps to ripping out acrylic shower stall enclosure and covering with tiles? Bacardi 151 Carpentry 3 10-30-2007 11:35 AM
