Joining Particleboard Substrate Before Laminating How Do I Prepare Joint? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 01-06-2016, 08:23 AM   #1
Demolition Mode
Rewards Points: 129
Send a message via Yahoo to HandyDave
Joining particleboard Substrate before laminating How do I prepare joint?
I am replacing a kitchen counter top because water got to the particleboard under the sink and it has swelled and rotted. It has been in place since 1969! I understand the whole laminating process with the contact cement, the question i have is i need to have a 121 inch substrate. When you doing them together (butt Ends) do i need to fill the joint with something? If so what do i use?
Thanks!
So many projects so little time!
Dave
HandyDave is offline   Reply With Quote
Old 01-06-2016, 09:13 AM   #2
Rewards Points: 144
If the joint is done properly there should be no gap to fill.I use biscuits and glue in the center of the board and 2 draw bolts on the bottom.
mako1 is offline   Reply With Quote
Old 01-06-2016, 09:15 AM   #3
Civil Engineer
Rewards Points: 5,246
Better to use plywood or at least OSB for the substrate, particleboard is too prone to swell and deterioration when it gets wet. I like 3/4 inch A-C plywood, biscuited at the joints.
Old 01-06-2016, 10:04 AM   #4
Demolition Mode
Rewards Points: 129
Daniel, Wouldnt OSB be to rough for the laminate to adhere to?
If i dont have a bisquit joiner is there another suggestion? I am not against buying one if i know i will use it again in the future...hey i just bought my first router after 50 years! :-)
Old 01-06-2016, 10:48 AM   #5
Civil Engineer
You can use Kreg screws, splines, dowels, or you can use a variety of router bits that make special joint shapes. The biscuit jointer happens to be fast and reliable, but certainly not the only way to join wood.
Old 01-06-2016, 11:04 AM   #6
Rewards Points: 144
.If you have a router I would use a slotting bit and spline.
I agree that osb would be a bad choice.I don't actually use particle board but a mdf board which is made for commercial cabinet shops in sheets 30" X120" but it's the same concept. Personally never liked laminate on plywood as is to unstable and will cup and bow.JMHO as many people do use it.
Old 01-06-2016, 11:16 AM   #7
Rewards Points: 144
There are thousands of posts on the net from people dissing the particle board family of products for laminate countertops.The fact is that it is flat and smooth.The exact properties you want for a laminate to adhere to.If your sink is installed properly there is no reason for the surrounding edge of the PB to ever see moisture.
The Following User Says Thank You to mako1 For This Useful Post:
HandyDave (01-06-2016)
Old 01-06-2016, 11:18 AM   #8
Rewards Points: 1,466
My choice would be to bore for pocket screws, size the joint but let it dry about 10-15 minutes ( depending on humidity ) rather than 2-3 hours. Then re-glue liberally and assemble with the final screw torque being by hand and just enough squeeze to see a little glue line squeeze out.
OSB for me.
http://lumberjocks.com/topics/19712
Old 01-06-2016, 11:26 AM   #9
Rewards Points: 144
Sizing the joint is a very good idea when working with PB and something I forgot in my post.The edges of that stuff can really suck up the glue.I suggested a spline with your router as much for alignment as structural strength . Alignment may be tricky with pocket holes on a 25" wide substrate.
Old 01-06-2016, 11:39 AM   #10
His sink has been in for 46 years and even plumber's eventually fails.
Old 01-06-2016, 11:43 AM   #11
Rewards Points: 144
+1 Cabinetmakers do to eventually.
Old 01-08-2016, 05:31 AM   #12
Demolition Mode
Rewards Points: 129
MAKO1 my wife is gonna be mad at you... i keep thinking i WANT a Plate Joiner now and Mernards has the Porter Cable on sale, plus the 15% off bag sale.... The temptation is so overwhelming LOL
Tags
adjoining , substrate
Taping and seams AlphaPilot Drywall & Plaster 20 12-27-2015 03:28 PM
Bad solder joints, fixable? ponch37300 Plumbing 10 11-18-2015 04:36 AM
do you have to tape joints? begal Drywall & Plaster 34 08-09-2015 08:42 AM
How To Solder Copper Pipes Termite How To Guides 69 11-13-2012 12:20 PM
Joining ABS to cast iron at a joint tns1 Plumbing 9 06-21-2010 01:05 PM
