Interior Partition Not Parallel In Kitchen - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-14-2019, 02:12 PM   #1
Rewards Points: 234
I'm running hardwood flooring throughout the house, including the kitchen. I have an interior partition that is not parallel to the exterior wall that I started the flooring from. The result is that over the ~7' span of this wall, there's about a 3.5" difference from one side to another as far as where the hardwood seam sits. This wall just so happens to have some kitchen cabinets on it, so I *could* simply bump out one end of the cabinets so that this run is parallel to the flooring, and leave the counter guys to scribe the countertops to fit. I know it would be tough to pick up a difference in countertop "depth" visually normally, but this is a LOT. What to do? Split the difference? Hug the wall and ignore the flooring?
Interior Partition Not Parallel In Kitchen-img_0043-1-.jpg   Interior Partition Not Parallel In Kitchen-img_0044-1-.jpg   Interior Partition Not Parallel In Kitchen-img_0045-1-.jpg
nobbyv is online now   Reply With Quote
Old 02-17-2019, 07:32 AM   #2
Rewards Points: 2,452
Re: Interior Partition Not Parallel In Kitchen
With that corner, the angle will show no matter what. There are the cabinets as well and you can't change them. I'd take your first option to scribe the counter to the wall. You probably will have to buy wider or a full sheet. If the material has a pattern grain, you must match it.
carpdad is offline   Reply With Quote
Old 02-17-2019, 09:28 AM   #3
Property Mgt/Maint
Rewards Points: 6,368
JMHO, to heck with the floor and run the base cabs to wall. To do otherwise would hide one issue which is on the floor, and create another at eye level.
[political signature removed]
Yodaman is online now   Reply With Quote
Old 02-17-2019, 09:32 AM   #4
Rewards Points: 334
I agree
Tymbo is offline   Reply With Quote
Old 02-20-2019, 07:29 AM   #5
Rewards Points: 2,273
The angle on the floor would bother me more than the angle on the counter. Unless your counter has a pattern, like tile, it'll be less noticeable there.
huesmann is offline   Reply With Quote
Old 02-20-2019, 06:01 PM   #6
Mystriss's Avatar
Rewards Points: 3,100
A bit more involved, but I'd pull the drywall and make the wall parallel to avoid all of the issues of flooring and countertop.
(I'm not a professional, just a homeowner who dabbles in a bit of everything DIY)
Mystriss is offline   Reply With Quote
Tiling kitchen - Subfloor has a hump. Bigmo59 Flooring 10 09-10-2014 10:29 PM
Kitchen, Dining Room, Pantry mprice214 Electrical 23 07-14-2014 11:45 AM
My new kitchen needs a facelift (oak cabinets have to stay) EclecticMom Interior Decorating 3 02-12-2012 09:45 PM
Double Bowl Kitchen Sink Drainage Problem PeteW Plumbing 16 09-05-2011 09:41 AM
New floor/subfloor in kitchen. Need ideas DanBress Flooring 3 10-20-2008 08:31 PM
