Insulating 2-bowl Kitchen Sink? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-13-2015, 08:14 PM   #1
ZZZZZ's Avatar
Rewards Points: 2,158
Insulating 2-bowl kitchen sink?
Anybody ever done this? Good idea or waste of time & foam?
From Family Handyman: http://www.familyhandyman.com/plumbi...dda07cf7#step7
Deaden sounds with expanding foam
Fill the space between two [COLOR=blue !important][COLOR=blue ! important]stainless [COLOR=blue ! important]steel [/COLOR][COLOR=blue ! important]sink[/COLOR][/COLOR][/COLOR] basins with expanding foam. The foam deadens vibrations and lessens the gong effect. It's possible to do this with the sink in place but much neater and easier before installation. Either way, let the foam harden and then trim away the excess with a knife.
ZZZZZ is online now   Reply With Quote
Old 12-13-2015, 08:22 PM   #2
Rewards Points: 996
i have a single bowl sink. i had some of that automotive sound deadner, wth is that name of that stuff ? peal and stick. i put that on there after the sink was installed.
made a large difference !!!!!
Fix'n it is offline   Reply With Quote
Old 12-13-2015, 08:33 PM   #3
Rewards Points: 2,128
Might be a good idea for some people.
I know you can always trim/cut away the foam like you said, but it just seems painful if you ever have to replace or work on your plumbing/faucet. Hard enough to work under a cramped kitchen sink.
Personally, I'm not bothered by the gong or metallic sound so I wouldn't do it, but it is a good idea. Just my opinion.
jmon is offline   Reply With Quote
Old 12-13-2015, 08:40 PM   #4
Rewards Points: 6,652
Nope. Mine has a rubber sound deadening pad on both bowels, like you find inside vehicles to deaden the road noise. Look up "Dynamat".
The Following User Says Thank You to gregzoll For This Useful Post:
Fix'n it (12-13-2015)
Installing kitchen sink cprao Plumbing 3 11-06-2015 08:55 AM
36" Kraus front apron sink in a 36" apron sink base - best way to cut/install? Quicksmoke Kitchen & Bath Remodeling 4 10-06-2015 11:18 AM
My kitchen sink smells like sewer kasgirl Plumbing 7 11-23-2012 04:57 AM
How bad/unusual is it for a kitchen sink under window to be off-center? Iron Petunia Remodeling 17 11-21-2010 06:33 AM
Kitchen Sink Moved - new kitchen sleepysmurf Plumbing 1 08-10-2010 06:38 AM
