Insulate Fiberglass Tub? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree4Likes
  • 1 Post By dannieboiz
  • 1 Post By Nealtw
  • 1 Post By Mike Milam
  • 1 Post By Nealtw
Old 03-27-2018, 08:43 PM   #1
Rewards Points: 636
insulate fiberglass tub?
Replacing a metal tub with a fiberglass whirlpool. Trying to avoid having to install a heater. Read that some people insulate it with either foam or fiberglass insulation.
Thinking about picking up a couple cans of spray foam insulation and spray the surrounds before putting it in. Would this give a decent insulation and provide a more solid feel to the tub?
dannieboiz is offline   Reply With Quote
Old 03-27-2018, 09:58 PM   #2
JUSTA MEMBER
Rewards Points: 3,544
Re: insulate fiberglass tub?
How long do you plan to live in this home?
Fiberglass tubs will eventually deteriorate and crack and leak and ruin the flooring. And maybe the entire structure.
They use Styrofoam stiffener blocks to support the tub, the Styrofoam deteriorates and the support is gone, then the fiberglass flakes off on the underside, eventually getting too thin to support you, and then you have a foot through the fiberglass , or a bare behind. OUCH.
Once you spray the foam to set your tub into, you have a limited amount of time to get it set right, or you will have a crooked tub.
Why remove the steel tub, is it rusted, or bad?
ED
de-nagorg is online now   Reply With Quote
Old 03-27-2018, 10:51 PM   #3
Rewards Points: 636
ED
I'll be using mortar to support the base. The insulating thing was just brainstorming probably won't do it.
The metal tub was chipping so we used it as an excuse to put in a whirlpool.
de-nagorg likes this.
Old 03-27-2018, 11:34 PM   #4
retired framer
Rewards Points: 18,464
The biggest heat loss is the surface f the water, I doubt you will ever notice a difference. When I had one no heater just add a little hot water if you stay there long enough for water to cool off.
Mike Milam likes this.
Old 03-28-2018, 09:41 AM   #5
Mike Milam's Avatar
Rewards Points: 152
That's what we do (add hot). I usually only use it at times when I'm really sore and stiff for overdoing something. I prefer showering as a rule. My dad asked me when I was about 15 years old why I would want to sit in water my butt is in, lol. Stuck with me.
Nealtw likes this.
Thank a police officer for being the one who runs 'TO' a report of shots fired, while everyone else runs 'AWAY'
Mike Milam is offline   Reply With Quote
Old 03-28-2018, 09:45 AM   #6
retired framer
I put one in and after two years I only used it to get the price per use down to something reasonable. The thrill wore off in a few month.
Removed vinyl siding row to finish deck in fiberglass. Need help to reinstall it. Jim_Lafleur Roofing/Siding 27 10-07-2015 01:46 PM
Improving attic insulation: remove old fiberglass or just add cellulose/fiberglass? DrSteveBrule Insulation 12 10-21-2013 11:42 PM
Insulate duct work svaic00 Insulation 2 07-21-2013 10:19 PM
difference between fiberglass insulation for house and ovens Druidia Insulation 2 08-03-2012 08:44 AM
cellulose over blown in fiberglass? deerhunter Building & Construction 1 10-29-2010 10:16 PM
