Installing Toe Kick On Ultracraft Cabinets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 09-01-2015, 09:10 AM   #1
Rewards Points: 44
Installing Toe kick on ultracraft cabinets
Hi,
I am a handy individual and I bought ultracraft kitchen cabinets for my reno and the tall cabinets do not have their toe kicks attached. Normally I see the toe kick integrated with the cabinet. In this case, the toe kick is a big square and the cabinet rests on that square. My question is how do I secure the toe kick to the cabinet? I know I can probably drill screws diagonally through them but that would look like an ugly hack. I am wondering what is the best way to attach the toe kicks when they come this way?
Thanks!
elsewhere is offline   Reply With Quote
Old 09-01-2015, 09:22 AM   #2
Rewards Points: 5,348
If the cabinet rests on this, it's a cabinet base, not a tow kick. A toe kick is a piece of trim that gets attached to the base under the cabinet. If you think you need to attach the cabinet to the base, shoot a couple of finish nails through the cabinet floor into the base.
Attach the tow kick the front. I usually wrap the base molding around the cabinet and turn it into a toe kick.
Ron
B. Franklin 1759
Old 09-01-2015, 09:28 AM   #3
Rewards Points: 44
Thanks for your answer. If that is the case then it looks like I just got the cabinet base. I don't see anything that looks like it should be nailed in front to be the toe kick. My problem is that the cabinet is tall and I don't have a lot of room in my small house to lay it on the floor, but I guess this is what I have to do - ugh! the cabinet is suppose to go floor to ceiling. I hope it wasn't measured too tall
Old 09-01-2015, 09:35 AM   #4
That's why you have the separate base. You can tilt the cabinet up and lift it onto the base. If they were attached, the cabinet would hit the ceiling.
Toe kicks are usually ordered separately. If you are using the base molding as a base, you don't need to order it with the cabinets. The cabinet guy should have gone over the options at the time of ordering. These matching toe kicks can be ordered if that's what you want.
Ron
B. Franklin 1759
Adding 12" upper cabinets to already 42" ? DIY-Her Kitchen & Bath Remodeling 10 02-23-2016 12:04 PM
Tiles before or after kitchen cabinets? nipab Remodeling 9 01-05-2015 11:19 AM
Installing outlets in cabinets Ebierley Electrical 7 02-06-2013 10:44 PM
Refinishing old Cabinets ryanb4614 Carpentry 4 08-18-2011 06:24 PM
installing kitchen cabinets ncoppola09 Carpentry 9 01-06-2007 09:07 PM
