Installing Stainless Steel Sink In Granit Counter Top? - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 02-04-2012, 05:05 PM   #1
installing stainless steel sink in granit counter top?
I want to install a stainless steel sink in a granit top but there is no room for the clips and the clip channel interfers with the top?
DJFlynn92 is offline   Reply With Quote
Old 02-04-2012, 05:22 PM   #2
It sounds like you need a different sink. It the edge of the stone finished at all? Can you undermount?
Zanfirico is offline   Reply With Quote
Old 02-04-2012, 05:27 PM   #3
Rewards Points: 17,890
If the sink is the right size and the edges of the counter top are finished then an under mount would work so much better and be eazer to clean the counter tops.
Old 02-04-2012, 05:33 PM   #4
no room for undermount!
Old 02-04-2012, 06:13 PM   #5
Rewards Points: 582
what did you take out ..get a direct replacement...or something is wrong....
Old 02-10-2012, 09:35 PM   #6
Rewards Points: 77
Sounds like the cut out for the sink in the granite is too small. There should not be any interferance with the clip channels. They should fit into the cut out opening. Talk to a granite fabricator in your area and see what they would do. You might need them to come to your place and re-cut the opening to the right size. I seem to remember that they grooved out small steps on the underside of the granite for the clips. Look at the clips that came with your sink. You might be able to modify them to work or come up with your own hardware.
MNsawyergp is offline   Reply With Quote
Did I ruin toilet/vent after installing sink??? nibeck Plumbing 4 09-06-2012 07:07 AM
Installing a Utility Sink rslackde Plumbing 0 06-03-2011 08:35 AM
Hand-Made Stainless Steel Driveway Bridge - Elba, MN, USA jrico01 Project Showcase 13 09-28-2009 07:12 PM
Reconnecting gas line- corrugated stainless steel handyman923 Plumbing 2 08-21-2009 06:20 AM
installing vessel sink drain?! (HELP!) tara Plumbing 2 11-10-2006 12:17 AM
