Installing Full Heigth Pantry Cabinets - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Old 12-24-2015, 09:25 AM
Rewards Points: 4
Installing full heigth pantry cabinets
How do I install full height pantry/utility cabinets (96"). The toe boards will be delivered unattached. I have installed cabinets before but not at 96"
rlscott1967 is offline
Old 12-24-2015, 10:03 AM
Retired Moderator
Rewards Points: 7,174
Most 'full height' cabinets have a separate toe kick/and base---if they don't, you will not be able to stand them up---as the diagonal measurement (corner to corner) will be taller than the cieling---
I did run unto a custom cabinet that was full height----so I cut the base off and built a new one----
oh'mike is offline
Old 12-24-2015, 10:27 AM
Rewards Points: 4
full height cabinets
As I said the toe board will be delivered unattached. My question is do I attach the cabinet to the wall or build a support platform then slide the toe board underneath or set the toe board and slide the cabinet on top.
Old 12-24-2015, 10:55 AM
Retired Moderator
Yep--wait till it comes to see how it is built.
If you use a loose base---that is placed first---then the upright cabinet can be lifted and slide on top of the base.
oh'mike is offline
Old 12-24-2015, 12:49 PM
griz's Avatar
Rewards Points: 572
You may have to adjust the height of the box slightly.
griz is offline
Old 12-25-2015, 10:21 AM
firehawkmph's Avatar
Rewards Points: 2,454
Level the base in both directions, then usually with a helping hand, lift the pantry cabinet straight up and slide it onto the base, then fasten to wall. They ship them like that so it makes it easier to stand the tall unit up.
Mike Hawkins
firehawkmph is offline
Cabinets To Go! CapnHawk Kitchen & Bath Remodeling 69 08-13-2017 06:02 AM
Installing Toe kick on ultracraft cabinets elsewhere Kitchen & Bath Remodeling 3 09-01-2015 09:35 AM
Installing kitchen upper cabinets, my soffiet is level, gain 1 inch over 15 feet Skip19 Kitchen & Bath Remodeling 4 09-25-2012 11:16 PM
installing new dedicated circuit - neutral bus full 7green Electrical 12 05-03-2011 01:32 PM
installing full frame windows with existing siding mlmaher Building & Construction 3 09-11-2008 07:56 AM
