Installing Elderly Safety Bar In Shower For Mom - Kitchen & Bath Remodeling - DIY Chatroom Home Improvement Forum
Like Tree17Likes
Old 01-04-2019, 06:45 AM   #1
Rewards Points: 136
Question
My 80+ year old mom needs this to prevent a fall.
My brother used a stud finder in a tiled shower stall for mom & couldn't find one. I was not here to check his work. Mom's house was built in 1959 and shower is original to house. Am in No. California. He drilled into tile anyway and left holes.
Did builders not use horizontal or vertical wood slats in all rooms back then everywhere? Is there a specific stud finder for tile?
Brother is not careful or thorough. Thought he would be for mom.... I'm stepping in to be the helper here to get job done and plug holes in tile to prevent mold. TY for any suggestions!!
LadeeDIY is offline   Reply With Quote
Old 01-04-2019, 06:56 AM   #2
retired painter
Rewards Points: 1,806
Re: Installing Elderly Safety Bar In Shower For Mom
Does the tile go all the way to the ceiling? can you locate the studs on the other side of the wall? Most builders don't add blocking to accommodate safety bars.
LadeeDIY likes this.
mark sr is online now   Reply With Quote
Old 01-04-2019, 07:07 AM   #3
JUSTA MEMBER
Rewards Points: 4,042
Get a better stud finder, some of the cheapies, won't find a stud sitting on one.
1959 should have studding, at either 16" or 24" on center.
As suggested try above the tile if possible, or from the next room, and measure distance from a shared wall, then transfer the measure to the shower side.
One can also use a stiff wire probe through one of the bad holes, to find a stud, poke the wire through the hole, until you touch a stud, mark the distance on the wire, pull the wire, place wire on wall, with mark at the hole, now you know where studding should be, try again.
Good for you, taking care of mom, she gave you everything as a child, it's time that you reciprocate as much as you can.
It shows good character in yourself wanting to help her.
ED
de-nagorg is offline   Reply With Quote
The Following User Says Thank You to de-nagorg For This Useful Post:
LadeeDIY (01-04-2019)
Old 01-04-2019, 07:23 AM   #4
Rewards Points: 6,132
Above advice is very good.
I'm only 71 and still doing pretty good, but I'm already adding a couple of grab bars. The unfortunate part about a fall is once you know you are falling it is probably too late to protect yourself. Expensive, but the sit down tub/showers are probably the best. If the shower is big enough just a sit down feature would help.
Best
Bud
I volunteer my help and opinions, but you are responsible for what YOU choose to do with that information.
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
Old 01-04-2019, 07:55 AM   #5
Rewards Points: 136
Thumbs up
Hi, No. The tile is 6.5 ft tall from the shower floor. There's a few feet of drywall above. There's another bathroom on the opposite side. Just a bath - my dad capped off the shower in that one 20 years ago.
We have a chair but mom won't use it. It makes her feel old. She likes grab bar idea better. Thanks for help!!
Old 01-04-2019, 08:03 AM   #6
Guapo
Rewards Points: 11,950
There is a fairly new product called a stud-less grab bar mount sold at Home Cheapo.
Guap0_ is offline   Reply With Quote
The Following User Says Thank You to Guap0_ For This Useful Post:
Old 01-04-2019, 08:05 AM   #7
retired painter
Most any stud finder will find the studs above the tile, just follow them in a straight line down the tile. You can buy safety bars that will reach from one stud to another.
As for the errant holes you can either use grout that is the same color as the tile or silicone caulk.
lenaitch, de-nagorg and LadeeDIY like this.
The Following User Says Thank You to mark sr For This Useful Post:
Old 01-04-2019, 08:15 AM   #8
Just tried my Zircon i65 on the tiled backsplash in my kitchen. Just below an outlet I knew there would be a stud on one side or the other and sure enough it lit up on the left. This isn't the newest model and not all that expensive. Be sure your brother is using what he has correctly by locating studs in drywall where you know they should be.
If you need a better one, maybe the rental places have a reasonable option?
Bud
Old 01-04-2019, 08:24 AM   #9
Guapo
What good is a stud finder when the studs are 16" OC & the length of grab bars are not multiples of 16 so you can mount it in one stud only? Even if you can find 2 studs to use, the mounting flange is wider than a 2x4. As I said, Homely Depot sells a stud-less mount which I haven't tried yet.
Old 01-04-2019, 09:21 AM   #10
JUSTA MEMBER
NIX on that studless mount, it's only a rubber suction cup thing, and with any weight, it releases easy.
And with age the rubber will decay, and be useless.
At least all the studless ones that I have looked at, I would not trust.
Tell your mom that younger people use a shower chair, I for one need one to scrub my carcass, I lost a leg below the knee 18 months ago, and my everything changed.
So it's not a matter of feeling old, it's a matter of hygiene.
Best scenario, is to have a built for handicapped shower built, with a designated seat, and wand , and grab handles, walk in.
But as an alternative, you are doing the best that you can.
ED
Old 01-04-2019, 09:38 AM   #11
Guapo
Then I had the wrong product. There is something better.
Old 01-04-2019, 12:13 PM   #12
Rewards Points: 1,272
Remove the tile and backer board and add 2x12 blocking between the studs - Jesus - it's ur mom and she's 80 for God's sake - do it up right for her !
195795 is offline   Reply With Quote
Old 01-04-2019, 05:28 PM   #13
Guapo
How much does mom weigh?
jimfarwell likes this.
Old 01-04-2019, 07:23 PM   #14
Rewards Points: 1,042
[QUOTE=de-nagorg;5728859]NIX on that studless mount, it's only a rubber suction cup thing, and with any weight, it releases easy.
This is a studless mount , not the rubber suction cup you mentioned.
https://www.supplyworks.com/Sku/8039...saAnVwEALw_wcB
Canarywood1 is offline   Reply With Quote
Old 01-04-2019, 07:52 PM   #15
Rewards Points: 7,564
Good point.
I have never mounted a shower grab bar, but when I search it, I see they are often shown being mounted vertically, so that they can be mounted on one stud.
Moen makes this system, but its basically the same principal as a toggle bolt.
https://www.moen.ca/products/Moen_Ho...Pair/SMA1000CH
SPS-1 is offline   Reply With Quote
Tags
bathroom tile question , safety and security , stud finder
Installing a shower from unused laundry hookup Vineta77 Plumbing 13 01-01-2016 05:46 AM
Installing shower in basement ryanmcl Plumbing 6 01-26-2013 04:09 PM
Installing shower unit inside bathtub mlinpdx Plumbing 2 11-29-2012 12:03 PM
Installing 2 shower heads on separate walls? mallory_ratliff Plumbing 2 07-12-2011 04:56 PM
Installing Shower in basement jburchill Plumbing 5 05-05-2011 12:14 PM
